Home > General Chat > bloody hell! it dont rain but it piss's it down! :(
clubminiflip
Member #: 54
nr coventry
christ i have the hump! had a hospital appointment this morn, all seems ok, on my way home my thermostat housing has blown off!!!! WTF snapped the bolts but these will come out ok fortunatly, *oh well*
what a nightmare! Temp got to about 3/4's up on the gauge & i got home to the garage, bonnet off & poured a can of water over it to help it cool, all seems ok on 1st looks, no real damage & i have parts to fix it!
the oil pressure light popped on a couple of times but i'm presuming at the mo that its cause the oil was hot & thinner than normal, although to be honest she is smoking a little :(
i'm not wanting a micra as yet! haha *happy*
Jackman
Member #: 984
Westhoughton, Bolton
Yikes, how the hell has that happened? Seems really bad, snapping the bolts! Must have been some force behind that.
Manchester Minis
clubminiflip
Member #: 54
nr coventry
cant understand why there was a pressure in the system, i only had it all apart about 2 weeks ago to flush thecooling system & rad, new pipes the lot! seems a wierd one to me cause all looks hunky dory other than the obvious, got me dirty wooley jumper on now to have a look & hopefully sort it all out!
if the oil pressure light has come on and its a standard one i'd be a bit worried. they're not set very high, 8psi isnt it?
Jackman
Member #: 984
Iain, thats a good point, they are set to 8psi, maybe lower.... if you have a low oil psi.... saying that are you sure it wasnt the alternator warning light, it could have been that, maybe why it overheated, not moving the waterpump.
Manchester Minis
clubminiflip
Member #: 54
nr coventry
I AM A LIL WORRIED ABOUT THE OIL PRESSURE! *happy* it was the orangey coloured light coming on rather than the red one daaaarrrrnnn! i'm not stressing to much, i'm hoping it'll last untill i have my next engine ready to put in,
i think i'm going to take the oil pressure thingy out & give it a clean, the cup & spring doo-dad!
alternater & associated compontents seem ok
maybe i've properly fooobarrrreed my standard 1000cc engine haha! i should'nt be laughing really as i have no other motor to tie me over, frickin aida! *happy*
Jackman
Member #: 984
Just put thicker oil in, that helps, if your running 10w40 change to 20w50, not the best thing to do but if it keeps you on the road then it will do the job.
Manchester Minis
clubminiflip
Member #: 54
nr coventry
DONT LAUGH!!! *happy* HEHE! thats what its been running on what a nightmare!
i'm gonna move the minivan out & take it into my garage 2moro & have a real good look at it cause its just to cold to work outside!
i've got a prety bad oil leak too! it was leaking but it seems alot worse now!
fingers are crossed! i'm smiling though JUST!
you say the oil light poped on a couple of times,
When? idle or at speed? on the straight or going round a corner, steady speed or acellerating?
clubminiflip
Member #: 54
nr coventry
well with my drivin style normally it comes on in the bends but it flickered a few times when going up a slight hill when the temp was hottest due to water loss, suffice to say i did drive like my gran when i was loosing water, aslong as tomorrow goes ok with the other jobs on my mini, other than using thick oil is there any cheapo oil leak fix's to keep the lil bugger going untill i get my motor built up?
Ric
Member #: 36
Basingstoke
how much oil is in it? Where is it on the dipstick?
clubminiflip
Member #: 54
nr coventry
oh its low, i have ot top it up once a week, sometimes a lil more depending on distance etc, it is leaking like a good british car should :) loosing far to much oil really, i got an advisery at mot time, should
Star Mag
Member #: 375
Leicestershire
My old mini had a knackered engine in it leaked like a sieve! used too fill that up when the oil light came on!!
clubminiflip
Member #: 54
nr coventry
oh it just gets better! took my clutch slave cylinder bracket off & sliced my hand open! been to the a&e to have butterflie stiches, for frick-sake, i only had that part to put back on before a test run too! pic is on the way
clubminiflip
Member #: 54
nr coventry
just to add to the probolems, i'll still work on the mini 2moro DEFO!
Jackman
Member #: 984
Ouch :( Not having much luck today :(
Manchester Minis
clubminiflip
Member #: 54
nr coventry
i'm getting worse i swear it!
the car seems to be holdiing water fine & dandy now! oild is coming out the back of the engine & there's alot around the diff & pot-joints, more on the passenger side when you look at it underneath, the front subby is lashed with oil, i cant really see where its coming from though,
i'm mulling over one of those minispares adjustible oil pressure do-dads, are they any good? anyone used them?
clubminiflip
Member #: 54
nr coventry
