| Home > Help Needed / General Tech Chat > fuel pump pressure | |||||||
93 Posts Member #: 1212 Advanced Member braintree, essex |
20th Feb, 2007 at 08:36:34pm
what sort of psi does an spi pump kick out max? its just ive bought a fuel filter which says "not for system pressures higher than 10psi" |
20th Feb, 2007 at 08:47:29pm
Its no use then.
20th Feb, 2007 at 09:50:20pm
its ok between the tank and pump though |
54 Posts Member #: 1425 Advanced Member Yorkshire Wolds |
20th Feb, 2007 at 09:54:56pm
If it helps, I measured the fuel pressure of a standard MPi tank/pump at the intake of the pressure regulator and it measured about 45 psi. If Spi / Mpi tanks/pumps are the same? |
20th Feb, 2007 at 10:01:22pm
TBI systems usually run around 15psi.
21st Feb, 2007 at 12:05:48am
On 20th of Feb, 2007 at 10:01pm stevieturbo said:
If placing a filter before any fuel pump, make sure it has adequate, unrestricted flow ability, otherwise you can cause pump starvation/cavitation, which doesnt do anything any good. Those are my thoughts exactly when talking about pre oil filter set ups. Back onto the fuel filter. Thing is we are talking about SPi/MPi tanks here where the pump is in tank, therefore you cannot fit a pre filter. Besides theres one already one on the pump may be not a fully fledged filter but its there. Have a look on ebay for fuel filters for the likes of Puegeot 206/7, IIRC they have barb fittings for flexi hose/clips/ and are Injection filters anyway. Fit the proper filter for the job
i use one similar. no pressure there!
