Home > Help Needed / General Tech Chat > Front Arches and 6 x 10 alloys
pickmeup
Member #: 1200
Hi all
Ive fitted 6 x 10 cosmics to the clubby and at the moment they dont rub the arches but im sure they will when the front suspension eventually settles.
Does anyone know (from experience) how much i should remove, I will be refitting my grp2 arches afterwards
Gaz
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Gaz,
normally I mock up the arches, mark up where they will come to and then mark around 10cm inside (smaller radius) the first mark.
Cut to the smaller radius and then bend the metal to 90deg to the outer line.
That way you get the most clearance possible and still have as stiff a panel as you would have had stock.
