Home > General Chat > bhp
1976_mini
Member #: 259
grays, essex
im sory its not much of a turbo question but, how much bhp could i expect out of a nearly standard 1275 mg metro engine with a water cooled oilfilter? oh and a straight through twin box 2" upswept backbox and main flow manifold and also how much could i expect if i wacked a turbo on it? thnx si
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
PaulM
Member #: 206
75ish and 95ish respectively
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
I ran my bog standard mg metro engine at the RR and got 48bhp a the wheels, apporx 72bhp at the flywheel.
That had k&n and 2 " exhaust and LCB.
Wouldnt whack a turbo on the mg metro engine as standard as the CR is too high but std metro turbos are 93bhp at the flywheel, roughly 60bhp at the wheels.
Iain
1976_mini
Member #: 259
grays, essex
what would i have to do to lower the compression ratio
machine the head, change the pistons or fit one of our spacer plates turbodaves designed, and I'm getting made
1976_mini
Member #: 259
grays, essex
how much does he sell them for?
does it go in between the head n block?
b12
Member #: 247
Kent/Surrey Borders
I am more than interested to know about the spacer plate ?
Assume you are going for a simple way to lower compression without machining the head ?
I still toying with the idea of two head gaskets .... for that 5 minutes of realiablilty !!
Please let me know what happens regarding the plates ; I am up 4 one ...
steve
TurboLessTosser
