| Home > Technical Chat > megajolt cranksensor | |||||||
59 Posts Member #: 1460 Advanced Member scunthorpe |
21st Feb, 2007 at 09:25:39pm
i have a spi mini block that im using to build my turbo engine, couls i use the crank sensor already fitted to the block to run megajolt or does it have to be the ford crank sensor?
21st Feb, 2007 at 09:26:37pm
oops that was meant to be a topic sorry do i need to re post as a topic? |
22nd Feb, 2007 at 12:14:17am
Youl need to modify the reluctor ring in the flywheel. If its the early SPi before 94 it will be a bit more tricky.
Edited by Sprocket on 22nd Feb, 2007. On 26th Oct, 2004 TurboDave16v said:
22nd Feb, 2007 at 12:15:37am
just thought actualy, you are still intending to use the SPi flywheel and flywheel housing,Yes?
27th Feb, 2007 at 12:04:45am
yes was going to use the lot
27th Feb, 2007 at 06:34:21am
The lack of a decent clutch will ultimately limit what torque you can run.
