Home > Help Needed / General Tech Chat > Urgent help needed re carb size and inlets for 1000cc
Richie
Member #: 628
ok. a standard G reg mini mayfair 1000cc. will this have 1" 1/4 or 1" 1/12 su on it ? and is the inlet manifold seperate from the exhaust (i know on the old 850`s they were one peice)
the reason i ask is there is a young lad in my area has bought a K and N element, a maniflow LCB and 2" system with stanless backbox (wants it to sound nice does not matter re performance) I said i would fit it for him today, but woke up in a cold sweat iam sure the exhaust and inlet system on the 1000cc engine is all one peice is it not ? i had a spare one in the garage which i have chopped up and it still wont fit over the center branch of the LCB.
anyone able to help, i cant get in touch with him to see what type of inlet he has :( i really dont want to let this kid down as he is excited about getting a loud car :)
please help gang advise me i know you will all have been here many times !!!
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
mattyking
Member #: 873
Thatcham, berkshire
hi, standard 1 litre well mine was all in one the exhaust mainfold and inlet. a stage one kit gives you separate inlet mainfold and then you need to get a 3 branch exhaust mainfold. standard carb size i believe for one litre was 1 and 1/4. hope this helps. im not certain on all this im sure someone else can clear this up if im on wrong track. But hope this helps
p.s if your not certain on carb size measure it, you measure the diameter of the flap.
Edited by mattyking on 23rd Feb, 2007.
My lads G reg Mini 30 should be the same.
That has a HS4, 1 1/2 inch carb on a combined inlet/exhaust manifold.
You will need a separate inlet manifold, or cut the inlet of the combined.
minimark
Member #: 19
newcastle
prob be a one piece on an inch andhalf, but you will never know till u look at it
minimark
Member #: 19
newcastle
3 replies in 2 mins ,,, not bad service
Richie
Member #: 628
mint service !!! i have cut one up i had but still dont fit plus in my rage have ground a pin hole in it now !!!!!!
i have an oselli torque master but it is for 1"3/4 and there is no way a lil 1" 1/4 will fit friggin N/A 1000cc pain in the ferkin arse !!! if it was 1275 it would be real easy !
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
The G reg Mayfair was fitted with the 1 1/2" HS4 carb at the factory.
This will fit the torquemaster manifold. It will only use two out the four studs, but it will fit.
I managed it on my bro's mini, if you cut the inlet off the exhaust and grind an arch in the middle.
You also have to flatten the top of the centre branch a touch, but if its not for performance gains then it doesn''t make much odds, and it would still be more free flowing than the standard one in anycase.
It is a fair bit of pissing around, but he was on a tight budget so you gotta do what you gotta do! Lol
Edited by matty on 23rd Feb, 2007.
Richie
Member #: 628
matty i have done that mod, but i just cant bring myself to "Ding" the center branch of an 80 quid maniflow LCB if it was a cheapo i would deffo do it *wink* he may want it in the future when i sell him a full 1275 unit Mooohahahahahaha :) i have found three manifolds that may suffice, thankyou all yet again for the info !!!!!! TM what a site
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
