| Home > Help Needed / General Tech Chat > Which grade of aluminium to use | |||||||
60 Posts Member #: 1066 Advanced Member germany |
23rd Feb, 2007 at 05:48:32pm
Hi Guys,
23rd Feb, 2007 at 06:37:33pm
H30, or if you want the bullshit name 6082 t4,
23rd Feb, 2007 at 07:25:04pm
cheers carl, i'll have a look for some of that |
1425 Posts Member #: 690 Post Whore Norfolk |
23rd Feb, 2007 at 09:05:38pm
I'd always go for steel on this part to ensure the bolt doesn't lose torque (putting the boss on the damper makes the joint inherantly weaker as you are putting more friction faces in the mix and the bolt has to maintain torque over all of these) - my opinion only, but a loose crank damper can do similar damage to the crank as a loose flywheel.
If Carling made Mini engines
23rd Feb, 2007 at 10:42:53pm
What!!!, i can assure you John' a loose damper will do little more then shag up the woodruff keyway, [experience] the cranks steel the dampers cast iron,
On 23rd of Feb, 2007 at 09:05pm johnK said:
I'd always go for steel on this part to ensure the bolt doesn't lose torque (putting the boss on the damper makes the joint inherantly weaker as you are putting more friction faces in the mix and the bolt has to maintain torque over all of these) - my opinion only, but a loose crank damper can do similar damage to the crank as a loose flywheel. you are putting all that torque onto a very small surface area (under head of bolt) - do the stress calcs to see if the material will yield under the "static" load generated by torquing the bolt up just my two penoths worth! JK |
23rd Feb, 2007 at 11:03:56pm
Arent flywheels cast iron? well the factory ones anyways.
Edited by Sprocket on 23rd Feb, 2007. On 26th Oct, 2004 TurboDave16v said:
23rd Feb, 2007 at 11:22:42pm
i found the kad one needed spacing off the pulley, the offset wasnt enough.... "Turbo's make torque, and torque makes fun"
23rd Feb, 2007 at 11:24:31pm
Not with the SC one, nice fit in both standard and MPi pullies On 26th Oct, 2004 TurboDave16v said:
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
23rd Feb, 2007 at 11:49:40pm
2014 is a good alloy but in the t6 condition is seriously hard!!! We had some sheet in at work and it cracked before we could get a decent fold out of it! A he15 alloy or a he30 alloy would ge more than up to the job. We use lots of these specs on almost all the alloy stuff on the historic f1 cars at work. For high stress stuff we use the he30, i.e suspension bits. p.s. sorry for bad typing/spelling had a lot to drink and have laptop perhed on the bed trying to type this!
23rd Feb, 2007 at 11:55:07pm
I am using a minispares longer socket headed bolt which comes with a 4.5mm spacer which I am pretty sure is steel (correct me if i'm wrong) and this is determining the dimensions of the hub. Here is a preliminary cad mock up.
24th Feb, 2007 at 12:13:20am
Sorry double post Edited by kitch on 24th Feb, 2007. |
24th Feb, 2007 at 11:30:50am
Hi Kitch - you are right the spacer on the m/spares cap head is steel - I may have a look at the calcs as well out of interest.
28th Feb, 2007 at 08:32:32pm
I did the analysis of the hub to mount my trigger wheel.
28th Feb, 2007 at 09:47:09pm
i don't and if i did i wouldn't tell you , lol . |
28th Feb, 2007 at 10:08:01pm
I don't get it, why? My uni lecturer said EN24T was the bar I should use and said I could get it from metalsupermarket in cov but I don't have wheels and thats miles from leamington spa. |
28th Feb, 2007 at 10:27:07pm
look in the yellow pages and find your local metal stockholders, most places will have one local. Spoilt for choice round my way, one in our town and loads in a ten mile radius! |
I think the same way you found out Carl
