| Home > Technical Chat > rod query | |||||||
3596 Posts Member #: 655 Post Whore Northern Ireland |
23rd Feb, 2007 at 10:49:15pm
In my neverending web searches for stuff I cant actually afford, or even need yet....
23rd Feb, 2007 at 11:09:10pm
How much?
Edited by Sprocket on 23rd Feb, 2007. On 26th Oct, 2004 TurboDave16v said:
23rd Feb, 2007 at 11:11:17pm
I'll keep it in mind and research it for next years build
23rd Feb, 2007 at 11:28:39pm
There is an offset to both big and little ends of A series rods.
24th Feb, 2007 at 12:24:14am
On 23rd of Feb, 2007 at 11:28pm danboy said:
There is an offset to both big and little ends of A series rods. Regards Dave Ahhh, just noticing this now..... Looks like a fair bit too. Oh well.... 9.85 @ 145mph
24th Feb, 2007 at 03:13:21am
I *think* someone is working on Alloy rods for production at the moment...
24th Feb, 2007 at 09:42:35am
Or, Dave
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
24th Feb, 2007 at 10:54:44am
JE pistons will do you a piston to your own specs. From what i gathered at the autosport show when i enquired they are supplied with rings, any number of rings, any deck height etc.
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
24th Feb, 2007 at 11:12:48am
LOL rods can handle 600bhp/9000rpm would be intresting, what else would break first |
24th Feb, 2007 at 12:10:30pm
Here are a few pics of my Ebay rods.
24th Feb, 2007 at 12:26:45pm
On 24th of Feb, 2007 at 03:13am TurboDave said:
I *think* someone is working on Alloy rods for production at the moment... I reckon these guys just need convincing that if they manufacture them - we will buy them! Longer rods will mean the JE piston (which is way too short, but cost-effective) will be a realistic proposition again? I also found these....I didnt think they were that expensive.. Although perhaps a bit bulky for a long rod option ? No doubt they could be sized down for a Mini application though. http://motorsport.bdg.com.au/conrod.html 9.85 @ 145mph
24th Feb, 2007 at 12:35:19pm
On 24th of Feb, 2007 at 12:10pm danboy said:
Here are a few pics of my Ebay rods. As you can see from the pics they are symmetrical and at first glance they appear to be a non starter. What I plan to do is to use an ally spacer on one side of the big end to give the required offset at the crank end. These will be fixed to the rod and cap with 3 off 2mm Csk set screws. The little end should be OK with just one side machined down by 1mm. It will mean that the rod shank is running offset to the piston centre line by 1.5 - 2.0mm (Do you think this may be a problem) The rods are bushed and the pistons I am using are Omegas which have large flats on either side. will PTFE buttons be OK to locate the pins or should I put circlip grooves in the piston? Would a press fit pin be OK if the bush is left in place as an alternative? How much side clearance between rod little end and piston boss is advisable to allow for crank flex? I think any input on these questions could prove very useful if alternative rods are to be found and used. These rods are german made and were bought from ebay for £30 +p&p. No sizes were given and as i work on a few different motors I took a flyer and bought them. They turned out to be spot on for length, 004" under on big end dia & 012" under on little end dia. Lucky or what! I contacted the manufacturer to find out there original application but unfortunatly they turned out to be arrogant and totally un cooperative. I did a little research at the time and the closest match came from a BMW car engine.(cant remember which). Regards Dave Would aluminium be a suitable material for the spacer ? What about Tig-ing a suitable piece of steel to the side of the rod cap ? Although I guess that might muck up the balance more... 9.85 @ 145mph
24th Feb, 2007 at 12:40:03pm
Stevie,
26th Feb, 2007 at 06:41:37am
Why bother ? Buy some 970S rods, they are about 1/8" longer and have smaller big end than A+. You can either buy a matching EN40B crank with S big end size or machine an A+ crank to S big end size (offset if you wish more stroke).
26th Feb, 2007 at 06:52:05pm
I never had rod problems on any of my mini engines...
26th Feb, 2007 at 07:21:03pm
so it would seem,
On 26th of Feb, 2007 at 06:52pm stevieturbo said:
I never had rod problems on any of my mini engines... Good point....maybe std rods are more than capable of handling any power we throw at them ? |
27th Feb, 2007 at 06:26:36am
It is true that a set of Carrillos, Arrows or whatever brand look really high tech compared to std rods. But when fitted no one sees inside the block.
27th Feb, 2007 at 08:14:23am
standard rods are fine, but if your after the best Arrow do some nice steel ones and for ultimate they can do titanium.
