| Home > Help Needed / General Tech Chat > PLENUM CHAMBER | |||||||
327 Posts Member #: 1145 Senior Member North Wales |
24th Feb, 2007 at 06:09:46pm
AWRIGHT LADS. iM PLANNING ON GETTING SUM PIPE TIG WELDED ON THE THE PLENUM CHAMBER.jUST NEED TO KNOW WHAT SIZE TO WELD ON?? aLSO WHATS THE MOST COMMON SIZE OF INTERCOOLER PIPE RUNNING OFF THAT.THANKS FOR ANY HELP.
24th Feb, 2007 at 06:49:44pm
use 1" or 25mm for the plenum dump valve take off
24th Feb, 2007 at 06:50:08pm
You couldn't have timed you post better, I've just been in the workshop drilling a plenum to fit a take off for a DV. The DV pipe is 25mm (1 inch) & most IC pipes are 52mm (2 inches). If you really want I can go and take some pics.
24th Feb, 2007 at 07:09:49pm
Rob .... it's all you you you isn't it .... should have been doing mine ... I've done your pulley after all ....
24th Feb, 2007 at 07:22:42pm
On 24th of Feb, 2007 at 07:09pm RogerM said:
Rob .... it's all you you you isn't it .... should have been doing mine ... I've done your pulley after all .... LOL Don't worry I'll bring you you're off cut of 25mm alloy pipe tomorrow. Isambard Kingdom Brunel said:
24th Feb, 2007 at 08:05:56pm
Cheers buddy ..... Every day is a school day ...........
25th Feb, 2007 at 01:12:22pm
you are aiming for something like this...
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
25th Feb, 2007 at 01:16:19pm
that looks pretty!
25th Feb, 2007 at 03:08:27pm
I kept the 46mm inlet and re welded it at a differant angle. then used a 45-52mm reducer to connect it in the the rest of the pipes.
25th Feb, 2007 at 09:09:41pm
On 25th of Feb, 2007 at 01:16pm martpaul said:
that looks pretty! Yes...It is yours... JF. On 21st Jan, 2011 fastcarl said:
![]() 35 Posts Member #: 1464 Member Liverpool |
1st Mar, 2007 at 05:25:33pm
JF. How much for something like that
Do you make them?? Ta Turbo power here I come! |
1st Mar, 2007 at 08:07:53pm
Yes I do, £35 on exchange.
1st Mar, 2007 at 08:20:26pm
id recommend JFs plenums excellent product and i dont think youll find cheaper no longer a series, but still 1.3 turbo.
2nd Mar, 2007 at 10:47:25am
Yes does look vey nice & very reasonably priced
