| Home > Help Needed / General Tech Chat > few questions - flip front | |||||||
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
25th Feb, 2007 at 11:29:05am
Edited by martpaul on 25th Feb, 2007. |
25th Feb, 2007 at 12:11:37pm
I am assuming you have bought a 2 piece front, if not I'd see if you can exchange it as it's actually a real pain in the but with a one piece as you seem to have to take it off all the time to do the most basic things.
25th Feb, 2007 at 12:22:50pm
yeah see ive studied that one, and many others, and none of them use/tell you how to attach the hinges!
282 Posts Member #: 1404 Senior Member The Netherlands |
25th Feb, 2007 at 12:27:54pm
hallo,
Edited by paneermeel on 25th Feb, 2007. there is nothing wrong with a A-series that a turbo can't fix.
25th Feb, 2007 at 12:29:45pm
http://www.geocities.com/MotorCity/Track/4..._Tactics04.html
25th Feb, 2007 at 12:30:20pm
That is because most people don't use hinges, they make a lift off front like shown in that article .... it is a much better solution to the problem! Every day is a school day ...........
25th Feb, 2007 at 12:33:19pm
It is worth using a stonechip / shutz on the underside of fibreglass panels as sharp chippings thrown up can impact the fibreglass hard enough to crack the gel coat on the top side, which will show up in the paint also.
25th Feb, 2007 at 12:36:39pm
paneermeel, that I think is the first decently engineered solution for a "flip" front I have seen, looks very neat.
25th Feb, 2007 at 12:42:37pm
Thats a really good picture!
25th Feb, 2007 at 12:45:49pm
yeah i like the look of the flip front! oh and my uncle doesnt believe it can be done!the idiot wont believe me that its a kit, and not something that i just imagined in my head! the look on his face will be great! |
25th Feb, 2007 at 06:07:39pm
can you post a pic of your hinges please, also how does your bonnet fix on? |
25th Feb, 2007 at 09:52:22pm
On 25th of Feb, 2007 at 12:36pm RogerM said:
paneermeel, that I think is the first decently engineered solution for a "flip" front I have seen, looks very neat. My only question though is why did you not mount the bonnet on the original hinges? What you have done though does get around the problem of the bonnet still being attached I suppose so you have full access from all sides. My only concern is how well the bonnet is located and if it is flexing the panels as it vibrates .... then again I guess the extra stiffness of a steel front is going to make that much less of an issue than a GRP one. i wanted a full flipfront, one wich would open all together. that's why i didn't use the original hinges. for strenght i welded a bar between the wings. (you can see that on the pic) on which i made triangelar plates. know my bonnet is secured by 2 bonnet pins at the window side an i use the normal bonnet lock in front. when the front is closed al you see are the bonnet pins en the dzuz fastners. if i want to check my oil i only need to clip open the pins en release the front lock. this makes it possible for me to use 2 bonnets i have. on standerd and on the other i made a powerbulge. i can swap bonnets in under a minute. will take some pictures tommorow off the hinges which i use to flip and how everthing is secured. no rattles and a pro for steel is you can make a perfect fit. bending and welding it together. there is nothing wrong with a A-series that a turbo can't fix.
25th Feb, 2007 at 11:57:18pm
Fairy snuff .... as I said .... one of the best I have ever seen. Every day is a school day ...........
26th Feb, 2007 at 09:56:55pm
ok been out working on this front!
26th Feb, 2007 at 10:18:50pm
On 25th of Feb, 2007 at 06:07pm gav said:
can you post a pic of your hinges please, also how does your bonnet fix on? pictures say more than words, i hope
this is how my bonnet stays on:
the normal lock on the front and pins at the back this is what i did to get the gaps even all around, i welded a bar between the wings. some plates added an presto
and these are the hinges i use. they can be split so i can take the whole thing off, and put it back on without the need of readjusting everything.
hope this helps you a little in making youre own flipfront. keep us posted
26th Feb, 2007 at 10:57:56pm
on my link at the bottom of my posts there is a picture of the hinges i used when i had a steel flipfront
Edited by Nic on 26th Feb, 2007. |
27th Feb, 2007 at 05:04:02pm
On 26th of Feb, 2007 at 09:56pm martpaul said:
ok been out working on this front! i have to put it under a little stress/tension! ie the wings want to pull in at the bottom by the a panel and rises at the part of the wing that lies on the inner wing! is this right?or should i say ok? just i dont wanna go ahead and fit it like that if its not! |
27th Feb, 2007 at 09:34:18pm
Thanks :) what car did you take the hinges off they look nice and sturdy |
27th Feb, 2007 at 09:59:11pm
ok been out working on this front! i have to put it under a little stress/tension! ie the wings want to pull in at the bottom by the a panel and rises at the part of the wing that lies on the inner wing! is this right?or should i say ok? just i dont wanna go ahead and fit it like that if its not! my experiance with polyesther is small. what if you add a small stip off alu to the front? blend that in. if it's thick enough it will the front in his right shape. picture would help:) @gav: they were lying around so can't say where there from. but i know the where car door hinges. if they can take the weight off a door they sure can hold if mini front. there is nothing wrong with a A-series that a turbo can't fix.
10th Mar, 2007 at 03:23:26pm
Right my mini is all about ready for spraying, the last thing todo is to fit this flip front this weekend!
10th Mar, 2007 at 05:54:21pm
i got the front resting on the part off the innerwing that is still there. with some foam on it.
11th Mar, 2007 at 04:09:21pm
ok this is where im at so far!
11th Mar, 2007 at 04:40:45pm
I have those hinges, make sure the hinge is at the bottom, you can bolt them to the where the brace bar bolts to the subframe. |
11th Mar, 2007 at 04:43:34pm
the holes are to wide to do that! :(
12th Jun, 2007 at 10:09:20pm
Did you manage to get that front fitted ok? 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
