Home > General Chat > Turbo it is....! Help needed!
sk8ernude69
Member #: 1524
Plymouth, Devon
Hi there, i have wanted to turbo a mini for a long while n have now decided to take the plunge....! I have sourced a complete turbo engine n 'box, downpipe, dump valve, in car bleed valve, boost guage, intercooler, oil cooler, fuel pressure regulator, turbo pre filter etc. I need to know what else i need and if i have overlooked anythin...!
I have seen turbo fuel pumps advertised at £115 new! I've heard there is an alternative of using an SPi tank with its integrated fuel pump, and also i could use a red top fast road pump. Are either of those true?
A 2" play mini stainless system is on the cards...? Will this fit the down pipe?
Bulk head box obviously... But do i have to worry about wiring or heater matrix behind the bulk head?
Anythin else anyone can think of would be very helpful!
Ben
minimark
Member #: 19
newcastle
use the search .. everything you need to know is there
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Spi / Mpi tank is the easy way of doing it.
2" PlayMini system is THE exhaust choice as far as I am concerned and yes it will fit the maniflow down pipe.
Be careful when you cut and all will be fine. Remove the heater brackets first if you plan on refitting. Lots of posts on heater mounting recently if you search.
