| Home > Help Needed / General Tech Chat > Difference between 1275 and 998 from outside | |||||||
487 Posts Member #: 1495 Senior Member |
26th Feb, 2007 at 10:36:42am
Picked up what I thought was a 998 cheap from scrappies on friday and just realised that the bores look to big for a 998. Is there any obvious difference on the block outer casing? someone said something about 2 extra plugs on a+ 1275? casing?
26th Feb, 2007 at 10:43:39am
Most obvious difference is that the 998 has only one core plug at the end of the block above the clutch housing, whereas the 1275 has two.
26th Feb, 2007 at 10:45:57am
yey!, i have a 1275 then. Hey im still learning but i already know 10times more than i did on thursday! |
26th Feb, 2007 at 11:04:51am
A 998 has removable covers on the back under the ports,a 1275 don't unless it's a 1960's cooper
