Home > Help Needed / General Tech Chat > Belgium mini project
beestje007
Member #: 1230
Hello, 4 months ago i bougt myself a 91' mini special, its stripped completly and i'm busy with the bodywork, removing rust and stuff like that, welding new parts,... the engine is a 998 and i want to put a 1275 turbo, but here in belgium its very hard to find a NA 1275, here in belgium a turbo engine from a metro doesnt exist, u will never find one! so my question is, is it possible to turbo my NA 1275? i already have a T2 from a R5, a T3 from a metro turbo, a turbo HIF44, plenum and in and outlet manifold. What i want from the engine is to produce like 90HP. what will i need to chance? maybe its possible to just add an oil cooler and working with low pressure, so maybe use the T2 turbo? thanks
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
If you search around this has been covered a few times since I've been a member (not long).
Basically the answer is yes but with limitations. 90BHP is unlikely though ..... try 100-110 and you might be in with a shout *wink*
I am really disapointed though. When I saw the thread title I was hoping to see pictures of a life size chocolate mini with a truffle centre........ mmmmmmm
JT
Member #: 637
Hertfordshire
if 90 bhp is all you want then a na 1275 should be able to achive that.
i think the metro turbo running at 4psi was around 95ish or was that when the soliniod raised it to 7psi after 4000rpm?
cheers
josh
My build thread..
RogerM
Member #: 1217
Standard Mety Turbo ran 94 bhp
if you can get a compression ratio of around 9 to 1 , then you should be ok to turbo that engine up to at least 7 psi , this should deff make more power than 90 bhp
a short duration cam would also help .
regards
robert..
paneermeel
Member #: 1404
The Netherlands
@beestje007:
in the netherlands there are few turbo lumps lying around. and the ones that are sold are going for huge prices.
i,m doing the same as you, building a na engine and modifing it to take a turbo.
lower the compression and rebuilding the lot.
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
