| Home > Help Needed / General Tech Chat > what is the best diff ratio? | |||||||
96 Posts Member #: 251 Advanced Member Nottingham UK |
15th May, 2004 at 12:40:45pm
I originally ran my engine and box as standard ie 3.21 diff and it accelerated pretty well, but box was never right, so I changed for a 3.44, but again box died, so I am going to rebuild one of the gearboxes but not sure which diff is better. I want real acceleration not too bothered about top end, but which would be better. I know in theory the 3.44 would give me better acceleration, but if the engine is torquey enough wouldn't 3.21 actually be quicker because of less gearchanges? Any ideas? |
15th May, 2004 at 04:40:45pm
I would wrote that if your engine is really that torquey, ie more than the std one, running without the ecu,I'm prefering the 3.1 dif, because even the 3.2 is a little short on higher hp's and torque, but if your choice is 3.2or3.44, use the 3.2, I'm quasi certain that a3.44 is undrivable when you are on good boost level and on the first gear,
15th May, 2004 at 05:48:20pm
The engine is standard turbo but am running without an ecu so the boost is constant 7 pounds. It was a bit of a handful with the 3.2 diff when it was running but never had it running properly with the 3.44 so may have been undrivable. |
15th May, 2004 at 05:57:34pm
16th May, 2004 at 11:20:00am
I will be running 13's eventually |
16th May, 2004 at 12:04:29pm
maybe a 3.76 wold be better, that woudl give you a top speed of 97mph at 6200 rpm On 15th May, 2009 TurboDave said:
16th May, 2004 at 01:41:52pm
so jimster you think that the 3.44 would be the better out of the two? |
16th May, 2004 at 03:24:08pm
I will never use 13's on a mini, heaviers, no more grip and less handy, my best choice are 5.5*10 on 165 a008 or a032r (amazing how they last are gluing with the tarmac), depend how often you want to change them , or a048r 155/55/12 on 5.5*12,
16th May, 2004 at 03:40:30pm
I'm running 10's, I'm going for a 3.44, but I have an lsd so I'm limited a bit on choice, also I have a much longer 1st gear (2.315:1 ) than most. On 15th May, 2009 TurboDave said:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
16th May, 2004 at 03:42:46pm
jim , shell wasn`t so sure on you having a much longer 1 Everyone knows that instructions only have to be read if the thing doesn't work....
16th May, 2004 at 03:44:40pm
how would she know anyway, we aint married On 15th May, 2009 TurboDave said:
