Home > Help Needed / General Tech Chat > ignition system / megajolt question
MarkGTT
Member #: 1194
Shropshire.
Hi all, am i correct in saying that if a standard mini ignition system is ballasted there would be a white and pink wire comming from the coil terminal??
just checking as mine is just white and i want to run the 12v feed for the megajolt from it and i know that it needs to be constant.
or should i be using an alternative power feed?
cheers.
bodgeit
Member #: 939
White should be permanent live from memory. Im sure others will confirm
calum_lorimer
Member #: 318
Edinburgh
I think you've got it right, ballasted is white with pink tracer and white alone is ignition live.
On mine i used a power feed straight from the fuse box so i could tape the coil connections back into the loom incase i ever wanted to/needed to convert back to dizzy.
MarkGTT
Member #: 1194
Shropshire.
cheers chaps.
Calum, did you get yours working in the end? what was up??
calum_lorimer
Member #: 318
Edinburgh
Ye, was just one bad connection that i missed. As soon as i sorted that my trigger wheel came loose though so there was lots of head scratching over two very minor problems.
