| Home > General Chat > Garrett T3 & T2 Turbo rebuild kits. Anyone interested in one??? | |||||||
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
2nd Mar, 2007 at 10:42:34am
I am currently in the process of talking to a supply of Genuine Garrett T3 rebuild kits and negotiating a price for a bulk buy.
Edited by Minimad69 on 2nd Mar, 2007.
2nd Mar, 2007 at 11:11:36am
sounds good to me! i dont want one but i supply them as and when i have time although mine arent genuine, they are the ones TT use etc.
2nd Mar, 2007 at 11:15:33am
Just got off the phone with the supplier and it looks like the final price will be £48 delivered for the T3 Kit.
2nd Mar, 2007 at 11:18:26am
How about Kits for the GT series?
2nd Mar, 2007 at 11:22:12am
mini13, i cant see a problem with being able to get hold of any kit for any Garrett turbo Edited by Minimad69 on 2nd Mar, 2007.
2nd Mar, 2007 at 11:58:12am
What is the most common type of seal for the T2 turbos "Carbon Seal" or the "Dynamic Seal" ?????
2nd Mar, 2007 at 12:20:06pm
I can get both the "Carbon Seal" & the "Dynamic Seal" T2 rebuild kits for about £63 delivered
2nd Mar, 2007 at 12:35:54pm
Most people use an R5 GtT T2 (phase 2 is the most popular) so what ever is in there. Not had a T2 apart so not sure .. Every day is a school day ...........
2nd Mar, 2007 at 12:47:59pm
Its the same kit for all of the T2 range, the carbon seal kit is used for cars running carbs, the Dynamic seal kit is used for injection.
2nd Mar, 2007 at 02:24:19pm
I thought that the carbon seal was the most common. But end of the day i bet the T2 i'm using is dynamic but most people will be using carbon. |
2nd Mar, 2007 at 02:55:08pm
Yeah iain the carbon seal kit is the most common for the T2 so most turbos should be using this kit but looking around most people just sell the one kit and dont say which seal is in the kit
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
2nd Mar, 2007 at 05:25:13pm
A rebuild kit for the good old t3 would be out use to me please, but still a turbo part collector.
2nd Mar, 2007 at 05:34:29pm
T3 Kits will be here middle of next week, ill post a pic when i receive them.
3rd Mar, 2007 at 08:05:14pm
i may need a rebuild kit for a escort rs turbo turbo can you get them or are they the same kit? no longer a series, but still 1.3 turbo.
4th Mar, 2007 at 03:29:36pm
if its a t3 which it should be on the escort carl then its the same kit
4th Mar, 2007 at 09:18:24pm
i thought theyd be the same. i might want one then ill have to strip the turbo first to check the shaft and housings before i commit myself first as theres no point in buying a kit if turbos scrap. no longer a series, but still 1.3 turbo.
5th Mar, 2007 at 07:19:14am
well if you decide you want one Carl then send me a pm
5th Mar, 2007 at 04:35:23pm
Garrett T3 rebuild Kits are now in stock.
32 Posts Member #: 1119 Member |
5th Mar, 2007 at 04:52:11pm
Kevin, can you get the balancing done?, or would you rely on just marking the compressor wheel to the turbine shaft when you disassemble the turbo. |
5th Mar, 2007 at 04:59:42pm
Hi minmog.
5th Mar, 2007 at 05:04:41pm
A VSR is a very expensive bit of kit but I'm sure it would soon pay for itself. |
5th Mar, 2007 at 07:46:18pm
Can you get the kits with the 360 deg bearing in? Every day is a school day ...........
5th Mar, 2007 at 07:49:24pm
On 5th of Mar, 2007 at 07:46pm RogerM said:
Can you get the kits with the 360 deg bearing in? Quite possibily, ill find out and get back to you!
6th Mar, 2007 at 09:48:16am
Can you get the kits with the 360 deg bearing in? RogerM, i can get the 360° bearing upgrade kit but they aint cheap. Its going to be about £142 delivered to your door
