| Home > General Chat > nuts | |||||||
93 Posts Member #: 1212 Advanced Member braintree, essex |
3rd Mar, 2007 at 12:05:42pm
dont suppose someone has got some nuts for the exhaust studs on a t2. i have been sent the wrong ones. i only need 2. |
3rd Mar, 2007 at 01:05:39pm
Think they're M8 so should be easy to get. I could be wrong though. |
3rd Mar, 2007 at 05:28:28pm
As Iain says they're M8 as sold in any hardware store, even B&Q!
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
9th Mar, 2007 at 08:22:14pm
K-Nuts are the ones to go for if you can be bothered to get hold of them. They are compact and use a smaller spanner or socket. 8mm nuts use a 10mm socket, 5/16 use a 3/8 socket. This is handy where space is tight to get to them. Not cheap, expect to pay around 40-50pence each.
9th Mar, 2007 at 08:37:40pm
Can you recomend a source? The place I normally get my hardware from is quoting significantly more than that .... I guess they are taking advantage of the fact we are in an areospace area :( Every day is a school day ...........
9th Mar, 2007 at 08:46:32pm
is that richard? i got them from u but have 4 spare 5/16th nuts as i needed m8 for the exhaust bolts lol its mike from Braintree. ill see if i can get some k-nuts from somewhere.
On 9th of Mar, 2007 at 08:22pm Mirage said:
K-Nuts are the ones to go for if you can be bothered to get hold of them. They are compact and use a smaller spanner or socket. 8mm nuts use a 10mm socket, 5/16 use a 3/8 socket. This is handy where space is tight to get to them. Not cheap, expect to pay around 40-50pence each. They are also a proper lock nut, they are much better than a nyloc, not that you can use nylocs on your manifolds. Be carefull buying cheap nuts from shops as they could be a very poor grade of steel and not all that strong. You can get silver K-nuts that have a higher temp tolerance, these are even pricer at about a quid each. |
9th Mar, 2007 at 09:14:02pm
On 9th of Mar, 2007 at 08:37pm RogerM said:
Can you recomend a source? The place I normally get my hardware from is quoting significantly more than that .... I guess they are taking advantage of the fact we are in an areospace area :( I use Merlin Motorsport over at Castle Combe, although that a bit of a long journey just for a couple of nuts. Isambard Kingdom Brunel said:
9th Mar, 2007 at 09:29:20pm
God, don't quote me on the price !! lol. I just buy them and dont really look at the cost. But i think it's about right for that size, they get more expensive as they get bigger and smaller, i bought some 3mm ones a while ago and they were over a quid each i think !!!!
