Home > 998cc > turbo build
weewheels
Member #: 1508
n ireland killyleagh
bit of help. Got myself a one litre metro engine today with 32000 miles on it (been in a shed for the past 10 year i was told and speedo said that.) hoping to turbo it. i also go a carb and plenum, of ebay. if i use the 12g940 head will that lower my cr enough. will be using a low blow turbo of a vauxhall diesel clutch mounted. will not be running a very high psi. i know i'll need other bits and bobs .will this be possible ????????
I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
http://s216.photobucket.com/albums/cc273/weewheels_2007/
Hi
If its std, the 12g940 will have just over 21cc chambers, on a 998 running flat top pistons this will give a relatively high cr for turbo use.
also with a 940, its usually necessary to pocket the block to gain valve clearance.
The 940 head has got the smallest combustion chambers if all factory cylinder heads.
clubminiflip
Member #: 54
nr coventry
joeybaby try to get a 12g295 head or speak to mr benross on here to sort your 940's chambers, there are ways you can pocket the block without a machine shop but time, being very careful & patiant is the key with a dremal!!! can be done though!
weewheels
Member #: 1508
cheers all. think i'll try and get a 12g295 head there has be one some where kicking around around this country.
