| Home > Help Needed / General Tech Chat > SC Drop Gears or SC Box | |||||||
4th Mar, 2007 at 10:08:51pm
As per a budget point of view what do you folks feel is more important? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Mar, 2007 at 10:21:18pm
How much power are you hoping to run? What is the car to be used for?
282 Posts Member #: 1404 Senior Member The Netherlands |
4th Mar, 2007 at 10:29:46pm
the first this that will break when the horses and torque go up are the drop gears so i would go for those.
there is nothing wrong with a A-series that a turbo can't fix.
5th Mar, 2007 at 08:33:09am
I am not of the opinion that SC gears in the box add that much strength, they just give better ratios. If you are upgrading the box I would say in order of importance is Diff, drops, box. http://www.twin-turbo.co.uk
146 Posts Member #: 1092 Advanced Member Yours from the Funny Farm |
5th Mar, 2007 at 12:39:54pm
could i fit Sc drops to the box myself though? what about a diff? Warning:Stig in Training
5th Mar, 2007 at 06:37:26pm
you need a x-pin diff, even a stock 998 will eat the standard one, never taken one to bits that isnt ****ed! |
5th Mar, 2007 at 07:54:12pm
Slaters not wrong... Every day is a school day ...........
14th Dec, 2009 at 11:13:09am
Bit of thread excavation here but I can't find the answers to my questions using search and this thread seems closest.
14th Dec, 2009 at 11:42:47am
Then limit the power to around 120, run std drops and a std box....
AlexF |
14th Dec, 2009 at 11:45:09am
Thanks for the input but I want it bit more power than that really. With the current spec of the engine 120bhp would be a waste. If something is worth doing, it's worth doing half of. |
14th Dec, 2009 at 12:01:28pm
Ear plugs then :)
AlexF |
14th Dec, 2009 at 12:33:21pm
in theory they should cancel out on the drop gears though... |
14th Dec, 2009 at 12:43:56pm
I'm assuming (possibly wrongly) the twisting effect on the helical idler causes the problem with a helical box as it will transfer this load to the layshaft via the input gear. then cause the engaged gear to climb the headset and possibly strip the teeth. If something is worth doing, it's worth doing half of. |
14th Dec, 2009 at 12:47:28pm
On 14th Dec, 2009 miniminor63 said:
in theory they should cancel out on the drop gears though... Lets not dig inot all that again On 12th Nov, 2009 Paul S said:
Gary's description is best |
14th Dec, 2009 at 01:19:34pm
no? Why not? to qoute TD:
14th Dec, 2009 at 04:14:27pm
If you want a little more evidence, just look at the thrust washers against the alloy casing - do you REALLY think this could take all the thrust of the helix if it wasn't in an idler train??? It is not a huge force
14th Dec, 2009 at 05:11:24pm
There not that loud anyway 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Dec, 2009 at 06:34:03pm
On 14th Dec, 2009 MikeRace said:
There not that loud anyway true, i have two sets in the twinnie and i just can't hear them when iv'e driving it, |
14th Dec, 2009 at 10:08:18pm
There not that loud anyway true, i have two sets in the twinnie and i just can't hear them when iv'e driving it, im not surprised you can hear the twinnie fire up a mile off
Yes i moved to the darkside |
15th Dec, 2009 at 11:49:33am
I ran mine with 140+ nanas as my daily drive a few years back, and never had any problems.
