| Home > Wanted > All the bits to change to Pre-Verto | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
4th Mar, 2007 at 10:21:24pm
As it says i want to change my set-up to a pre-verto clutch. Does anyone have all the bits that i need? I am able to collect from many places as my dad is a lorry driver, so it saves on people having to post them. If you have any bits that might help me, please send me a PM or you can email me at luke.ansley@ntlworld.com
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
4th Mar, 2007 at 11:51:30pm
i have a pre verto flywheel and back plate. name a price
5th Mar, 2007 at 12:05:21am
Thanks for the reply but i really need everything, the flywheel cover (wok) etc. And whatever other bits are needed, i think that its the flywheel clutch setup, the 'wok' and the slave cylinder. But i may be wrong, there may be more.
5th Mar, 2007 at 10:34:52pm
Anyone? |
5th Mar, 2007 at 11:06:30pm
The wok is the same,just buy a new arm,plunger and clutch release bearing as if you get used ones they will usually be worn which will give you clutch not disengaging problems
Edited by Dangerous on 5th Mar, 2007.
5th Mar, 2007 at 11:37:53pm
On 5th of Mar, 2007 at 11:06pm Dangerous said:
The wok is the same,just buy a new arm,plunger and clutch release bearing as if you get used ones they will usually be worn which will give you clutch not disengaging problems I expect you will need a inertia starter motor and solinoid too I have got the Inertia starter, this is where i first found the differences in the ring gear. I changed it to the inertia starter to get clearance for the intercooler and radiator at the front (it's a metro). Where do you recommend is the best place to by the new arm, etc? Thanks |
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
19th Mar, 2007 at 05:12:58pm
I am just about to do the same thing. Minispares seems to have all the bits, I got their new catalogue from mini magazine this month Check out the (slow) progress at.......
19th Mar, 2007 at 06:32:53pm
i have a flywheel, cooper cast backlate EN8???? grey, urrrm and a few slave cylinders kicking around
