Home > Help Needed / General Tech Chat > gear selector problem
minimadsheff
Member #: 1391
sheffield south yorkshire
Hello my fine turbo buddys! after a long time coming i have got my first turbo engine in it hole! after concting the gear selector shaft to it i found i was un able to get any gears, on closer inspecstion i found that the selector pin in the gear box has been bent just befor it go's in to the diff housing!!! aaarrrrrrrrr was what i said!
do you think if i bend it back it will get the gears or do i look into stripping the gear box and replace!!!!! please help it isn't bent that bad!!!!
70 mph oil feed pipe pop!!!!!
You could try bending it but its 1/2" thick. Youll probably have to replace the shaft.
Paul
minimadsheff
Member #: 1391
thanks paul like i said it's not that badly bent, also is there a way to replace it without having to take the gearbox off???/
Personally I would try and bend it back, you've got nothing to loose really.
Maybe a bit of localised heat could help to bend it back?
Have you tried to select the gears by hand with the linkage disconnected, or is it the bend limiting its travel?
minimadsheff
Member #: 1391
i think the bending is limiting travel but that was my thought some heat and a steddy wack with my LITTLE hammer!!! !
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Be careful you don't damage the diff casing bending it.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
danny also had this problem with his (pot_dan) but he ended up having to change gearbox it was never right after he bent it back :(
remember to change both the outer seal and the inner one (the ring wuith an 0-ring behind it usually) if you are going to heat it up they will likely melt
http://www.minispares.com/Product.aspx?pid=35775
turbo hogster
Member #: 178
stowmaket suffolk
i doubt it would be any good after beding back as its held in place by ally and that will proberly crack the main case. and needs to be a true slide inside the main metal runner.
box out job realey to do it proper and replace with a staright one
i think you can get uprated versions of these from she engineering (the place that sold those mechanical clutch conversion iirc)cheaper than a genuine one costs?
dont have a link to hand though.
RogerM
Member #: 1217
http://www.shengineering.co.uk/pcmselectorforkshaft.aspx
Ah but isn'nt that the selector "fork" shaft not the slector shaft,
RogerM
Member #: 1217
It is ..... however there doesn't seem to be anything on the other shaft on the site. I rang him today about something else and hoping he'll get back to me, I'll ask for details then .....
at least it's teh right site ... which is a start .... LOL
minimadsheff
Member #: 1391
just to let you all know i have solved the problem. it only need a slight tap back and now moves very freely i can get all of the gears too
thanks for the tips
jamesfawcett
Member #: 218
congratulations!
