Home > Technical Chat > stabiliser
Mark1275GT
Member #: 886
London.
You know that part that sits on the bulk head for the engine stabiliser, seen in the picture.How do i get to the the lower nut ?? I cant seem to find an exit to them .. cheers
Mark1275GT
Member #: 886
London.
http://img206.imageshack.us/my.php?image=e...abiliserik1.jpg
Mark1275GT
Member #: 886
London.
The bolts wont come off :(
it will prob be inside the car under the dash...
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Uses the bolt holes that teh left hand drive pedal box would have used.
I normally leave that bracket on once mounted unless I am painting the car. There should be enough movement to get the bar free from it, then remove from the engine end.
Edited by RogerM on 6th Mar, 2007.
Turbo Shed
Member #: 30
Epsom, Surrey
i welded the bracket in place so cant remove it. never had a need to remove it either.
the nut you are looking for is inside the car and its a bit tricky to get to
it helps to have an extra pair of hands, unless your mr tickle
Mark1275GT
Member #: 886
London.
There is no way to get to the bottom of the nuts from inside my 1275GT :(
Really need to get this off :( anyway else know.. thanks
RogerM
Member #: 1217
Mark, there is a way, trust me!
Behind the bulkhead carpet and sound deadening you will find a recess in teh bulkhead the same as the one the pedal box uses on the other side of the car. The nuts will be in there.
Mark1275GT
Member #: 886
London.
Oh never looked behind the carpet, durr.. lol
Ill try that thanks :)
Mark1275GT
Member #: 886
London.
I must be bloody blind.. cant see nothing... took everything out.. hmmm odd... can someone send me a picture plz.. be very greatfull
righto, look under the steering column, and look where your pedals meet the master cylinders...
its in in the same place.....on the other side
Mark1275GT
Member #: 886
London.
Got it off :) thanks to me girlfriend holding me nuts from inside the car lol shame they wasnt mine lol
