| Home > General Chat > handling VS power!? | |||||||
9th Mar, 2007 at 01:01:52am
hi
Edited by JT on 9th Mar, 2007. My build thread..
9th Mar, 2007 at 01:17:02am
well josh look at the link at the btm
Edited by BENROSS on 9th Mar, 2007.
9th Mar, 2007 at 01:28:10am
so your saying it will have a bad effect on handling?
9th Mar, 2007 at 02:01:48am
the roundabout i was very...... steady josh
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
9th Mar, 2007 at 02:52:38am
The turbo engine, unless it weighs more than your 998, will not effect handling.
Edited by Lance Link on 9th Mar, 2007. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
9th Mar, 2007 at 07:00:21am
In theory, more power will not affect the handling at all. However, in reality this isn't quite true.
9th Mar, 2007 at 02:55:38pm
i was suprised at how close he stayed reliy! but then he couldnt getaway atall either!
My build thread..
9th Mar, 2007 at 02:59:19pm
Basically, if you run any decent level of power from a turbo, you need to learn to drive again.
Edited by Kean on 9th Mar, 2007. |
9th Mar, 2007 at 02:59:44pm
only to the nearest banana "Turbo's make torque, and torque makes fun"
9th Mar, 2007 at 03:02:44pm
t2 clubby would you say it handles well though? and could beat a lot of things on the twistys etc?
My build thread..
9th Mar, 2007 at 03:48:20pm
Left foot braking is the only thing that annoys me in my 998 as it just stops the car as apposed to upsetting the rear, it works ok in the wet but there is not enough power to overcome the brakes on the front if that makes sense. |
9th Mar, 2007 at 04:53:14pm
never tryied left foot braking!
My build thread..
9th Mar, 2007 at 05:13:29pm
On 9th of Mar, 2007 at 03:02pm josh_tacon said:
t2 clubby would you say it handles well though? and could beat a lot of things on the twistys etc? cheers josh My car handles great, but thats only because I know how and when to let the engine loose, you have to be really carefull when to feed the power in, because of the way its delivered. This is all assuming you are going for a high boost setting of course, if running moderate boost levels it will be much easier to control through the twisties... Just get used to the way your car is and know your limits. |
9th Mar, 2007 at 05:47:50pm
thats the key thing i think and thats know your limit!! and the car of course
My build thread..
9th Mar, 2007 at 08:16:01pm
That is another reason I don't like big boost and do like high CR for a road car, just makes it so much nicer to drive on the road, a tall final drive also helps tame things a little too.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
9th Mar, 2007 at 08:31:29pm
Swapping your 998 to a 1375 turbo lump would have no effect on the cars handling at all. The difference in weight is so small. Change the brakes or other bits and it's a different story. It's simply not going to change the mechanical grip.
9th Mar, 2007 at 08:38:53pm
:) Every day is a school day ...........
9th Mar, 2007 at 11:48:42pm
what i was saying though i could be flat out in 2nd gear going round a corner and i have enuff grip to go faster, but iv run out of gear! so with my turbo engine i should be able to go faster round a longer corner with the longer ratios. im going to use a t2 with a 3.1 fd and jk ratios, which i think are the st ratios? somthing like 65mph in 2nd on 10s at 6500rpm? sound right to you?
My build thread..
