Home > Help Needed / General Tech Chat > Turbo Build Questions
AshP
Member #: 1464
Liverpool
Hi all,
I'm still at the initial stages of my mini turbo build and have a few questions. Firstly, I would like my mini to be able to get to 60 in about 7 seconds(ish). To do this would I be right in thinking about 120 horses would be enough? Consequently, I was thinking of running the engine at about 10 psi to achieve this (but only at weekends, most of the time I would prob just run it at lower boost *wink*)
So far I have got myself a standard metty turbo engine & box which is stripped and I'm servicing. I have done a lot of searching on this website and this is what I was thinking of adding to the standard spec:
4 pin diff
phase 2 cam
renault 5 turbo intercooler
bleed valve
dump valve
& possibly sending off my head to benross as i have read he is very good with them & could enlarge it to get the CR down!
So, am I being a bit optimistic here or am I going along the right lines?!
Thanks for any feedback *smiley*
Turbo power here I come! *happy*
Alex1340
Member #: 111
Loughborough
Sounds like you are going down the right lines to me, 120bhp out of a 1275 turbo should be pritty easy. I would get the head enlarged definatly a good plan. put a good head gasket on it as well.
AshP
Member #: 1464
Liverpool
ok cheers mate & thanks for the quick response.
what head gasket would you recommend then?
also I am just quite concearned that the engine should not have any problems running this boost - the last thing I want to do is blow it up once I have it up and running! and also is the 0-60 time realistic?
cheers buddy
Use the Payen BK450 head gasket, this is the proper Turbo one.
10psi if a fairly conservative figure compared to what a lot of folks run, so providing the engine is well built and properly setup, you'll have no trouble running that.
Hopefully you're includinga full transmission overhaul in your rebuild ? *smiley*
AshP
Member #: 1464
Liverpool
yes I am rebuilding the transmission too. when i bought the engine it was ment to have been rebuilt only a few thousand miles ago but i noticed some wear on 2nd syncro mesh so going to be getting a new 2nd gear & replacing the bearings etc *oh well*
Cant wait to get it all up and running!
Nice website btw very helpful indeed!
AshP
Member #: 1464
Liverpool
I just had a look on minispares at the head gasket you recommended http://www.minispares.com/Product.aspx?pid=37447
This says that it is for 1300 engines, however mine is still a standard 1275 block. which would be the best for mine or will this still fit?
T3Tone
Member #: 252
Sunny suffolk
Thats the gasket you want, it will fit as it is the 1275 turbo gasket. In fact i use it on a 1380 with no problems.
-MINI CLUBMAN 1380 TURBO-
AshP
Member #: 1464
Liverpool
OK Cheers buddy
