Home > Help Needed / General Tech Chat > ANother Engine Mount Question
b12
Member #: 247
Kent/Surrey Borders
I gotta hold of a pair of those yellow two piece engine mounts
does anyone know if they are anygood ?
Also is the turbo engines harder going on the mounts ? ( i would have thought yeah ?)
TurboLessTosser
just use standard genuine mounts. Well up to the job, just make sure its part of your regular inspection. They're not expensive and having that engine firm will be better than letting it move! *smiley*
1380Turboman
Member #: 221
I had those 2 piece yella mounts on my mini 1000cc and they pulled a part. Best to fit the standard mounts in my opinion.
nobbie
Member #: 162
and to make things easy to fit weld the nuts onto the engine mounts, saves a lot of fiddling about
I tend to disagree with the nuts bit really, thing is you can damage the threads when trying to line them up, never found it hard to do all the mounts up on my own with nuts and bolts, put the bolt in from the inside as then if the nut comes off there is a chance it will stay in, more so than putting them in from the outside.
