Home > General Chat > Supercharger or 7 port
Alex1340
Member #: 111
Loughborough
Right here the choice take 1 1275cc engine (or 1293, 1340, 1380) and add either a Vmax supercharger kit or a minisport 7 port head? which would you do?
Supercharger4 Votes 4 Votes - 0%
7 port head.1 Votes 1 Votes - 0%
other (please give us your idea)4 Votes 4 Votes - 0%
Carl
Member #: 95
liverpool-on-sea
both, yeehaww!
Neither, as none are proven to be as good as a turbo'd 5 port.
Minimad69
Member #: 1311
Yeovil, Somerset
And both cost a small fortune
mini23
Member #: 1296
Milford Haven Pembrokeshire
I know this is a turbo site but the supercharger has its advantages in certain areas.
And if you fitted it yourself (as most of you do with turbo's) it wouldn't cost a small fortune.
id go for the 7 port, just because ive always wanted one
but the gains from the supercharger would potentially be greater....
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
BMW K head with a turbo .....
I agree with roger, partially...*tongue*
The easiest cheapest way will be a turbo'd 5 port,
A supercharger although it will not have the same outright horsepower as a turbo setup is still a very good setup as there is no lag or boost threshold or whatever you want to call it. Although with the right turbo you can pretty much eliminate it anyway.
The 7 port has been made a bit redundent now by John K's kit's, with a similar amount of farting and cost about you get 16 valves!! if the bimmer parts had been available when i bought my 7 port i would have probably gone that route.
