| Home > Help Needed / General Tech Chat > Oil cooler fitting? | |||||||
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
18th Mar, 2007 at 03:47:20pm
Unfortunately my turbo engine never came with a oil cooler. I will need to fit one. I’m not sure how though? Where does it connect up on the turbo engine?
18th Mar, 2007 at 03:56:28pm
look behind your distribruter, see that pipe that goes to the oil filter housing from the front of the block?
18th Mar, 2007 at 04:05:20pm
Hmmm, this one:
18th Mar, 2007 at 05:00:49pm
yes, you got it!
18th Mar, 2007 at 05:05:27pm
18th Mar, 2007 at 05:15:45pm
LOL!! Cool. Thanks guys.
18th Mar, 2007 at 05:20:25pm
Yes a metro turbo came with an oil cooler from the factory.
18th Mar, 2007 at 05:25:14pm
I might be being stupid but I thought the turbo didn't have the carb overflow pipe bolted to the clutch cover as the carb is sealed. On 28th Aug, 2011 Kean said:
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
18th Mar, 2007 at 05:31:27pm
LMFAO Jon
18th Mar, 2007 at 06:42:27pm
Hmmm. Wonder why mine has got some different stuf on it like its missing the oil cooler and it has the overflow The carb was sealed on mine as it had the special screws.
18th Mar, 2007 at 06:46:52pm
might be worth checking the engine no to see if its proper turbo lump, also whip the rocker cover off and check for 2 different diameter valvestems. On 28th Aug, 2011 Kean said:
18th Mar, 2007 at 06:48:50pm
That is not what is meant as sealed ...
18th Mar, 2007 at 07:05:26pm
It should have a green colour oil pressure sender if it's straight out of a metro turbo,as they operate the other way round to the mini ones(no pressure open circuit)
18th Mar, 2007 at 07:07:47pm
Hmmmm. I dunno. i saw the car it came out of and it was a metro turbo. Its got the whole turbo setup. The part where the pipe from the bottom of the turbo goes into the back of the block. Seems to have ll of it although im no expert.lol
18th Mar, 2007 at 07:47:49pm
thats the anti run on and i think that was on all metty turbo's.
18th Mar, 2007 at 08:07:43pm
Oh right. Yeh iv seen it on a few of them in pictures.
18th Mar, 2007 at 08:43:08pm
just to be safe? it does just as much harm to the engine to run with to cool oil, as to run with to hot oil. |
18th Mar, 2007 at 08:46:06pm
I just want to fit one as they came with them standard tbh.
18th Mar, 2007 at 10:27:51pm
That isn't the anti run on valve, its the float chamber vent valve to stop vapour locking in the carb with a hot turbo and to aid hot re-starting.
18th Mar, 2007 at 11:03:09pm
Yes, Tom's right. Now you've posted pics of it with everything mounted I think I probably is a genuine one.
18th Mar, 2007 at 11:11:34pm
mattress+ garage im not liking that!!! no longer a series, but still 1.3 turbo.
18th Mar, 2007 at 11:42:51pm
Tom Fenton wrote: That isn't the anti run on valve, its the float chamber vent valve to stop vapour locking in the carb with a hot turbo and to aid hot re-starting.
Oh right, cool. I hadn't a clue what it was. cheers. RogerM wrote: Yes, Tom's right. Now you've posted pics of it with everything mounted I think I probably is a genuine one.
If your going to fit an oil cooler then fit a thermostat so that it runs only when required. Hehe, you did have me worried for a moment then to tell the truth. Ok, will make sure i do that. Carl wrote: mattress+ garage im not liking that!!!
Its not what you think...Honestly!lol. Nah, i was using it for the mini to rest on when i was doing the floorpan. best way to do it if you ask me. Edited by hammoj28turbo on 18th Mar, 2007.
