| Home > Help Needed / General Tech Chat > What is this bit on my turbo engine? | |||||||
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
18th Mar, 2007 at 03:57:13pm
I started stripping my engine down to paint the other weekend and I discovered that to take the turbo off along with the manifold I would have to remove this pipe that connects on to the top of the turbo/manifold.
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
18th Mar, 2007 at 04:03:34pm
It is indeed the oil feed, not sure what you mean by adjusting it? You can buy braided turbo oil feed hoses from all over the place to replace that pipe.
Edited by AL on 18th Mar, 2007. |
18th Mar, 2007 at 04:08:46pm
james it looks like to me buddy that every gasket and oil seal needs changing
18th Mar, 2007 at 04:09:38pm
Thanks very much. A braided one would be much better. Will do that.
18th Mar, 2007 at 04:11:29pm
are you going for a full rebuild ? Erm, i wasn't going to go for a full rebuild as the engine was running fine before it came out of the car apart from the fact it was running a bit rich. I was just gonna replace all the seals and gaskets then rebuild the carb and see what happens.
18th Mar, 2007 at 04:12:35pm
Thats the oil pressure light sender
18th Mar, 2007 at 04:19:03pm
Ah, that would explain. Cheers.
