| Home > General Chat > ICE question | |||||||
18th Mar, 2007 at 06:17:01pm
Guys, Im clueless with this sort of thing and dont read max power, so hopefully one of you can shed some light on this for me.
18th Mar, 2007 at 06:21:15pm
if you have 2 outputs one for front and one rear connect the front to a 4channel amp and rear to a single or two channel with low pass filter Crystal Sound Audio said:
18th Mar, 2007 at 06:35:41pm
On 18th of Mar, 2007 at 06:17pm joeybaby83 said:
And finally, do subwoofers need special amplifiers? or is an amp an amp? Some amps have low pass filters built in to work with subs, others will require you to use separate low pas filter. Isambard Kingdom Brunel said:
18th Mar, 2007 at 06:36:31pm
thanks wolfie, so, just to double check:
18th Mar, 2007 at 07:04:53pm
yep if your only using 2 speakers (the 6x9's) you only need a 2 channel amp.. but depending on the rating of the head unit you could just run them off that, however the amp 'should' will give a louder better sound.
Edited by MarkGTT on 18th Mar, 2007. |
18th Mar, 2007 at 07:15:39pm
not really made my mind up what sub to use, just using the one above as an example (had the link to hand).
18th Mar, 2007 at 07:23:08pm
just checked and the amp you have can be 'bridged' at 1 x 2000 Watts @ 4 ohms
![]() 673 Posts Member #: 1395 Post Whore chepstow |
18th Mar, 2007 at 07:26:16pm
you might want to search around on this forum
82 Posts Member #: 1278 Advanced Member Bedfordshire |
18th Mar, 2007 at 08:29:36pm
i compete in the IASCA sound off competitions and il let you know now you dont want 6x9 you want a nice set of components in the front and a amp to run them if you do want some rear fil id just go for a set of co-axials |
18th Mar, 2007 at 08:49:47pm
agree with above.. but for every day use 6x9's will be fine..
lol.
