| Home > Help Needed / General Tech Chat > Camshaft timing | |||||||
9 Posts Member #: 1595 Junior Member |
19th Mar, 2007 at 08:59:21pm
Hello, I'm french and I'm going to change the camshaft of my metro turbo engine.
19th Mar, 2007 at 09:04:50pm
You will only need an offset key if the standard timing with the normal key is incorrect.
19th Mar, 2007 at 10:27:41pm
Yes but my goal is to have the right off set key in the same time of the camshaft.
19th Mar, 2007 at 11:03:38pm
Avonbar Racing do a pack for around £17 plus postage ????
20th Mar, 2007 at 07:41:27am
As I build several engines a year I always keep lots of these. From 1 to six degrees. I always feel if an engine is a one off, you'd be better of with an adjustable setup. Easier, and not that much more expensive to be honest. On 13th Jul, 2012 Ben H said:
