| Home > Help Needed / General Tech Chat > oil return | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
22nd Mar, 2007 at 06:01:40pm
hey chaps, right after making my own oil return plate at work i came to fit it and mock fitted the turbo on an old 998 head.
Edited by fordimus maximus on 22nd Mar, 2007. 'always keep a spare shot for a stray bird' |
22nd Mar, 2007 at 06:30:37pm
you need to drop the pipe inlet on the plate you made further to the btm
Edited by BENROSS on 22nd Mar, 2007.
22nd Mar, 2007 at 06:47:04pm
thanks, thought id made it wrong!! whats ur opinion on the oil feed, and how easy is it to acess once its all in 'always keep a spare shot for a stray bird' |
22nd Mar, 2007 at 06:53:42pm
What block are you using? The 998 block is about 3/8" shorter than a 1275.
![]() 100 Posts Member #: 1426 Advanced Member Birstall, Yorkshire |
22nd Mar, 2007 at 07:01:52pm
should the standard turbo block come with an oil return pipe adaptor plate where the N/A mechanical fuel pump usually goes? or is it just summat you gotta make yourself? |
22nd Mar, 2007 at 07:03:50pm
yes it comes as standad on a turbo whole engine
22nd Mar, 2007 at 07:05:48pm
Is it better to just put a blank and tap a hole into the back of the gearbox? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Mar, 2007 at 07:08:59pm
well im using a cooper spi 1275 (1300) block. dont supose using a 998 head to mock up will have any effect on where the turbo sits. i thought they were pretty much the same? 'always keep a spare shot for a stray bird' |
22nd Mar, 2007 at 07:09:59pm
So where abouts in the gearbox you put the return? Any pics would be fantastic! |
23rd Mar, 2007 at 10:05:17pm
well i cut the pipe and re-welded it closer to the bottom, so when its fitted its pretty close to the bottom of the hole in the block, but its still fouling the turbo!!!! now im really stuck?? 'always keep a spare shot for a stray bird' |
23rd Mar, 2007 at 10:45:24pm
Post a picture mate .... sure we can work this out! Every day is a school day ...........
26th Mar, 2007 at 05:23:30pm
still stuck chaps, the only thing i can think of is that the head is different being off a 998!! cant see how it can be tho.
26th Mar, 2007 at 05:50:27pm
This is how Jimbo has his.
Edited by MikeRace on 26th Mar, 2007. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Mar, 2007 at 06:06:23pm
I'll try to get a picture up of a standard one off Candice's engine later ... got to go to the garage to tidy up ... shell is coming back this week .... hopefully!! Every day is a school day ...........
26th Mar, 2007 at 06:08:10pm
thats a nice job, but dont really want to cut in to the box casing as the engine is all assembled!
26th Mar, 2007 at 06:30:37pm
Jamie .... just a tip buy the way ..... run some thinner (something like a 5w10 or something) clean oil backwards through the turbo before fitting. It has been stood for a while and although it was wrapped I'd still prefer it if you flushed it before fitting .... better same than sorry!!!!
27th Mar, 2007 at 12:54:01pm
well sorted it guys, thanks for the help. just have to wait for my head from morspeed then im laughing!!! if i ever get it back!!!! 'always keep a spare shot for a stray bird' |
27th Mar, 2007 at 01:30:22pm
Come on then, share the way you sorted it for anyone else that may have the same problem at some point????
27th Mar, 2007 at 05:33:09pm
well cut the pipe off (again) and managed to get it so its sitting absolutely flush will the hole in the block.
27th Mar, 2007 at 05:41:30pm
Glad to hear that you have it sorted .... feel slightly better that my pictures last night came out so black you couldn't see a thing ..... odd.
