Home > Ebay items For Sale > inlet manifold but abit diffrent
Alex1340
Member #: 111
Loughborough
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...54549&rd=1&rd=1
Item number: 140096554549
any one seen one of these? can't see the point.
Ric
Member #: 36
Basingstoke
is it from a midget?
Alex1340
Member #: 111
Loughborough
must be, would never fit under a mini bonnet.
wouldnt of thought it would fit a midget either as it would come too high.
IIRC midgets use the same inlet manifold as mini's.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Meastro?????
danboy
Member #: 1381
Definetly a maestro 1.3
It,s where I got most of my HIF44's from.
Regards
Dave
Alex1340
Member #: 111
Loughborough
i bet some one has cut a massive hole in there bonnet and fitted one... there are crazy people out there.
I've wondered if they flow any good, could be a good manifold for FI
Definately not a Midget manifold, for starters all A series Midgets wherehas twin HS2 & the 1500 Midgets had twin HS4. The HS2 manifold is almost identical to the one on the classic Coopers, however I think (and I might be wrong here) that the angle of the maifold is slightly different. As an aside there aren't many single SU manifolds that will fit a midget without the dash pot fouling on the bonnet, so far the only one I've found that fits is the Maniflow one.
Sadly I've seen it done, you can guess what it looked like.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Defo 1.3 Meastro/Montego, have seen one on Mini and you do have to cut the bonnet.
I did think about using one for a turbo years back, no heat sink into carb.
JF.
