| Home > Help Needed / General Tech Chat > running rich (overfueling) at idle | |||||||
119 Posts Member #: 772 Advanced Member new york |
24th Mar, 2007 at 09:04:58pm
had car out two days ago no problems
24th Mar, 2007 at 09:27:46pm
no there shouldnt. your needle valve is knackered or has crap stuck in it.
54 Posts Member #: 1425 Advanced Member Yorkshire Wolds |
24th Mar, 2007 at 09:44:18pm
May also be worth verifying your fuel pressure output from the regulator, which should be between 3.5 - 4 psi. Theres no reason I believe for your pressure to change if the regulator adjustment screw is locked up, but its certainly worth getting the pressure set right.
Edited by Roadrocket on 24th Mar, 2007. |
24th Mar, 2007 at 10:05:24pm
just removed will clean it all out also will check float height
