| Home > General Chat > plenum pipe size? to fit silicone hose.. | |||||||
24th Mar, 2007 at 09:08:14pm
Hi all, i dont have access to the car tonight and wanted to order some parts.. but i and need the diameter of the plenum to turbo pipe sizes, so the actual plenum pipe and the stubby one that goes to the turbo.
Edited by MarkGTT on 25th Mar, 2007. |
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
24th Mar, 2007 at 09:45:35pm
They are about 45mm (measuring the pipe not to the edge of the bead) I use 45mm silicone hose and it fits nice and tight over the bead |
24th Mar, 2007 at 11:21:28pm
ill be using 2" (50mm) hose and its snug. "Turbo's make torque, and torque makes fun"
24th Mar, 2007 at 11:54:05pm
How many do you need?
25th Mar, 2007 at 09:32:24am
cheers chaps im after silcone hose to sort the intercooler i had in my head it was about 2".. anyone used that ZENA RACING stuff? from ebay think you order from hong kong, but its really cheap. Edited by MarkGTT on 25th Mar, 2007. |
193 Posts Member #: 437 Advanced Member Sunny Blackpool |
25th Mar, 2007 at 10:40:00am
I found 50mm internal piping to be pretty slack, and not very promising for an airtight fit.
89' Metro Turbo
25th Mar, 2007 at 11:09:39am
Mark, Ive used that Zena Racing loads and its good stuff, the stuffs usually here in a couple of days which is fantastic considering its from HK "Turbo's make torque, and torque makes fun"
25th Mar, 2007 at 11:52:03am
is it as good as samco stuff?
My build thread..
25th Mar, 2007 at 02:57:50pm
its all 3 ply silicon hose, but its wall thickness is a midge's dick less than the samco, but it wount make fa difference in our application. "Turbo's make torque, and torque makes fun"
25th Mar, 2007 at 03:00:14pm
I've just used zena racing too, they seem ok, i had a boost gauge that was faulty and they sent a replacement without much bother. On 28th Aug, 2011 Kean said:
25th Mar, 2007 at 03:42:21pm
just put an order in to Zena Racing, will post some pics when its all done. |
