| Home > Help Needed / General Tech Chat > oil gallery plugs for "A" block | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
24th Mar, 2007 at 11:27:09pm
ok anyone know where i can get oil gallery plugs from for A series block ? I have em for A+ but they are different, they do fit, but as the engine 8nt mine iam not 100% confident about using them in case they fail / drop out. The A series ones are the solid brass plug type.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
24th Mar, 2007 at 11:44:59pm
same bore size though, |
25th Mar, 2007 at 05:13:06pm
yeah like i say Carl, they are in, and i put a smearing of red hermatite on em prior to fitment, iam just worried that summit goes wrong and it 8nt my engine. its a full works 1430 N/A engine so failure is not an option on any component.
25th Mar, 2007 at 05:21:28pm
did they fit snug?
25th Mar, 2007 at 06:41:21pm
they were snug, i use a socket that fits in (just) then tap em it so the rim of the core plug suts about 1/2mm back from the face of the block, not sure what you mean by stake the edges though ?
25th Mar, 2007 at 08:54:49pm
Use of a punch to deform the edges to make a mechanical means of keeping it where it should be.
26th Mar, 2007 at 12:25:33am
rodge, will give em a tap or two, cheers for the info.
