Home > Help Needed / General Tech Chat > MJLJ questions
Richie
Member #: 628
ok, although on a tight budget, i am considering going the MJLJ route.
Questions.
1) does this system still utilise the dizzy, or do i blank it off ?
2) what do i need ?
3) is it greatly beneficial to me ie reliability and running quality ? i have 1275 engine with phase 2 cam running 12psi - 14psi boost (when completed)
4)how much does the kit usually go for ?
5) are the maps fixed or does the module have the facility for "Live mapping" via laptop when the car is being used ?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
1. The Mj does not use the dizzy or the drive (important to remove), and is blanked off.
2. From a ford Fiesta or similar 95 ish you need a coilpack (NOT red one), EDIS module and VR sensor.
http://cgi.ebay.co.uk/EDIS-module-coilpack...1QQcmdZViewItem
You will also need a 36 toothed crank pulley and a bracket to hold sensor in postion. And of course the MJ unit itself.
3. MJ shiould be more reliable as it is far more modern components being used, but saying that I have never had a problem with my Dizzy. Lol
4. I paid 100 quid for the MJ unit, 70 for pulley and bracket, and about 30 for Ford parts, as I was lazy and couldn't be arsed to take them off myself. LOl
5. Im unsure on the mapping side, as I haven't had my setup yet, will find out in two weeks though. :)
When you take into consideration that you can sell you dizzy now, it makes the conversion really cheap for the advantages!
Edited by matty on 27th Mar, 2007.
T3Tone
Member #: 252
Sunny suffolk
more info here http://www.autosportlabs.net/index.php?title=Main_Page
-MINI CLUBMAN 1380 TURBO-
Alex1340
Member #: 111
Loughborough
Simon at morspeed is doing a batch of pulley at the moment on a exchange basis, he is doing 5 and 3 are spoken for, one of which is mine.
Richie
Member #: 628
ok cheers folks.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I'd certainly make sure MJlj is on your build list as what it costs you will be more than made up for by the improved ignition control allowing a higher CR thus better economy and also the improved drivabiltiy and reliability over a dizzy.
If your think of a front mounted rad in a round nose then it's nearer essential than desirable IMHO as even though you might get it all in ..... have fun working on the dizzy afterwards!
Richie
Member #: 628
yeah it is going to be a massive front rad, so i guess that is my route to take then :)
cheers guys
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
