Home > Help Needed / General Tech Chat > Crankshaft Regrind
webba
Member #: 1495
When would you consider a crankshaft to be in need of a regrind? The journals on mine are in very good condition and only a couple of the journals have very-very minor lines on them. No grooves whatsoever.
Does it need reground anyway? The bearings were in good nick too. (Ill replace these obviously tho)
Have them measured to find ovality and taper. You cannot feel this. Have someone with know how to check.
webba
Member #: 1495
Cheers for the info
Dangerous
Member #: 417
Just get it re polished then
