Page: |
Home > 998cc > VTEC killer | |||||||
19 Posts Member #: 1612 Member France |
28th Mar, 2007 at 11:52:33am
this my mini project after long day of reflection.
Edited by AlexB on 28th Mar, 2007. |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
28th Mar, 2007 at 12:14:32pm
put some thought in to what intercooler you are going to run. This can make or brake performance on a good engine.
28th Mar, 2007 at 12:23:03pm
A water and oil pump is a good idea, you cant put metro turbo pistons in a 998, as ric says you might as well start with a 1275 block. |
![]() 2514 Posts Member #: 1217 I like nice quiet girly Minis Cheltenham, Gloucestershire |
28th Mar, 2007 at 12:38:46pm
junk the metro dizzy and go for MegaJolt or similar.
28th Mar, 2007 at 12:58:44pm
my problem is the 1275 metro turbo block have a failure!! but i have 998 mini engine completly rebuild in my garage for free. and the intercooler i will use is a VW sharan front one from the 1.8 turbo engine |
28th Mar, 2007 at 02:15:28pm
But has that rebuilt 998 been rebuilt with forced induction in mind? On 7th Nov, 2008 Nic said:
![]() 162 Posts Member #: 1252 Advanced Member Cornwall |
28th Mar, 2007 at 02:46:49pm
Exactly what is wrong with the metro turbo engine you have? |
28th Mar, 2007 at 03:17:32pm
I suspect that "tieeger" is not from the UK?
28th Mar, 2007 at 04:42:37pm
Good advice dave. Basically, you're in the right place, all the info you need is here. But do a ton of reading in the FAQ and Beginners Tech sections before planning or buying anything. |
28th Mar, 2007 at 06:58:41pm
that's right i'm french. and i have two david vizard book: _how to modify your mini and yellow one than you talk about. the 998 engine have a center main strap and a 12g295 cylender head with 29mm exhaust valve and 33mmm inlet valve |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
21st Apr, 2007 at 12:59:24pm
I must reckon 998 doesn't seem the best way to go if your goal is ultimate power.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
21st Apr, 2007 at 02:37:54pm
A good 998 turbo is much better than a stage 3 1275 IMO, but a 1293 tubo is always goig to make more power.
http://www.twin-turbo.co.uk
Page: |
