| Home > Help Needed / General Tech Chat > gaining oil pressure from a 3 year stood engine. | |||||||
30th Mar, 2007 at 03:35:17pm
My turbo engine has stood round for a good few years now, I fancied getting it running natrally aspirated as the turbine shaft is not spinning perfectly freely. so i have removed the turbo, oil cooler and associalted pipework.
30th Mar, 2007 at 03:41:34pm
its dead. give me the engine
30th Mar, 2007 at 03:49:16pm
Keep trying, it will take longer than 5 seconds to build oil pressure up. As long as it is just cranking over it shouldn't hurt anything.
30th Mar, 2007 at 04:40:27pm
30th Mar, 2007 at 05:46:32pm
yep, as above whip the plugs out, take the bolt out the oil transfer pipe and pour some oil in, then pour some more in, reatach and spin over.
30th Mar, 2007 at 05:57:26pm
I have to do that everytime...must be the type of pump I have or something On 19th Jan, 2010 wil_h said:
30th Mar, 2007 at 06:17:48pm
I've heard over tigntening the pump can cause it to leak down, can cut through the gasket or something... On 28th Aug, 2011 Kean said:
30th Mar, 2007 at 06:26:06pm
put the pipe in the front as described fil with oil then put car in a forward gear and roll it backwards so the oil goes into the pump do this a bit then try .
30th Mar, 2007 at 07:34:54pm
30th Mar, 2007 at 08:38:16pm
Pffff, every time a start my Mini it takes 5-10 seconds of idling before I get any pressure! I wonder how long I can nurse it along like that. On 7th Nov, 2008 Nic said:
30th Mar, 2007 at 08:46:45pm
just been out turning the engine backwards, gonna crank it over on the starter tomorrow.
30th Mar, 2007 at 11:04:42pm
so why do I have to prime my engine all the time? Not sounding dim? On 19th Jan, 2010 wil_h said:
30th Mar, 2007 at 11:16:56pm
What brand pump is it?
31st Mar, 2007 at 12:03:55am
Every couple of days maximum...mine needs oil prime....but did later pumps have bits of plastic in them to quieten them down?...maybe talking out me arse on this one....... On 19th Jan, 2010 wil_h said:
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
31st Mar, 2007 at 10:38:18am
i use minisapres pumps and blueprint them as per ACD. Some of these pumps are really shocking with lobe-casing gaps all over the place and end float nearing 15thou. All of that cant help keep oil in the pump and i can belive it when you say you have oil pressure probs.
Edited by andeh on 31st Mar, 2007. I've seen the future and tbh its Pie
31st Mar, 2007 at 12:13:46pm
After a lot of back filling, bleeding and cranking I have finally got 40psi on the starter. wahoo!
31st Mar, 2007 at 12:44:40pm
butterpopy,
31st Mar, 2007 at 07:19:33pm
Cheers mini13 m8... I shall try a few things first...then if all else fails, I'll ring Avonbar :) On 19th Jan, 2010 wil_h said:
31st Mar, 2007 at 10:52:36pm
My minispares pumps (yes, ive tried one after the other) all took seconds of running to build up oil pressure.
