Home > Help Needed / General Tech Chat > Bizzare Alternator Problem
b12
Member #: 247
Kent/Surrey Borders
Chaps
ever seen this one b4 .....
With the ignition on ; and engine not running ... my ORANGE charging light is OFF
When I start my new turbo mini ; and the engine IS running the ORAANGE charging light illuminates
SO I guess its not charging !!
Have 12V down at the alternator with ignition on ( brown.yellow wire )
but am totally confused as I tried another alternator as well ...
I rekion a earth problem ... Any ideas fellow turbo mini boys
OH yeah I am now one of those !!
Steve
TurboLessTosser
Was your mini always negative earth?
Are you Actully getting charge from the Alternator? ie 13+volts...
b12
Member #: 247
Kent/Surrey Borders
hey TD
yes always neg earth
I didnt have a meter with me today; But I will test it tomorrow !
Cheers mate
TurboLessTosser
Arno
Member #: 233
Beugen, Netherlands
One wire from the ignition light should go to 12v via ignition switch, the other wire goes to the alternator.
It lights when the engine is not running making earth through the windings, as soon as the engine runs the alt makes 12v and therefore the light receives 12v from both sides so the light shall go out.
check this and you prob will find the answer there
billydude
Member #: 48
Leicester
I thought the orange light was the oil pressure light *wink*
and you have the metro turbo oil pressure switch in which is the oposite of the mini one as in when pressure is achived the light comes on instead of going out *laughing*
b12
Member #: 247
Kent/Surrey Borders
billydude
I think u are right
i folowed the wires and did some tests with a meter
the orange light does go down to the oil warning light
and the red down to the alternator !!! via a brown/yellow wire
So assuming that I am wrong about orange being charge indicator and red being oil and you are right !!!
Red being charge
orange being oil
then I dont have a problem !!!
ANyone follow my message ???
With the ignition on only the red illuminates
start the car and the red goes out ( CHARGING ??)
and the orange comes on (cos the metro sender is telling me I have oil pressure )
Anyone ???
steve
TurboLessTosser
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
sounds reasonable!
I just use my oil pressure gauge... if then engine pops I have a spare or two hehehe
alex
AlexF
billydude
Member #: 48
Leicester
yup thats right *smiley*
pop a mini sender in and the light will be normal ie off when oil pressure is acheived *smiley*
Still go with a gauge though if you can, gives a much earlier warning *smiley*
Gibbo
Member #: 34
If you use the metro turbo relay, connected as shown in the FAQ section, then the oil light works correctly.
But, you should also be fitting an inertia switch to the fuel pump and ignition. This is not shown on the fuel pump diagram.
