| Home > Help Needed / General Tech Chat > Bailey Dump Valve Stangeness | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
22nd May, 2004 at 08:07:39pm
Chaps TurboLessTosser |
![]() 213 Posts Member #: 249 Senior Member |
22nd May, 2004 at 09:01:26pm
not much help but my cosworth used to be the same....if you raise the revs slightly you should see it close
22nd May, 2004 at 10:17:15pm
Baileys are not ideal for turbo minis.... the rubber seals don't like fuel or something like that? On 17th Nov, 2014 Tom Fenton said:
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
22nd May, 2004 at 10:32:50pm
I've heard that the piston can become contaminated causing it to stick, most people seem to use the diaphragm type on the A-Series.
23rd May, 2004 at 11:25:58am
Hehe im loving this, i will face no problems with b12 sligthly ahead Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
23rd May, 2004 at 04:38:50pm
I had this problem with my bailey dump valve, the ruber seal grows for some reason, my got to a stage where it would never close, so I had to bin it! On 15th May, 2009 TurboDave said:
23rd May, 2004 at 05:45:21pm
ah poo i have one of these |
23rd May, 2004 at 10:14:38pm
stick it on ebay mate On 15th May, 2009 TurboDave said:
23rd May, 2004 at 10:29:35pm
I think the rubber seals swell up a bit because of fuel contamination!!!!!! But it is possible to get special seals that dont react with fuel. Edited by T3Tone on 23rd May, 2004. -MINI CLUBMAN 1380 TURBO- |
24th May, 2004 at 09:06:50am
in that case, I'll give you a tenner for it Nic On 15th May, 2009 TurboDave said:
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
24th May, 2004 at 10:16:14am
the standard seals are made from nitrile which reacts with the fuel causing them to swell so the valve siezes. The seals needed are made from a material called viton. |
24th May, 2004 at 10:28:50am
good tip, cheers ngl, where can we get them from?? On 15th May, 2009 TurboDave said:
24th May, 2004 at 10:48:57am
Anywhere mate, we use them at work although i doubt in the right sizes.
