| Home > Help Needed / General Tech Chat > metro downpipe | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
23rd May, 2004 at 05:46:19pm
anyone know if the downpipe on a metro turbo can be used on a mini? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
23rd May, 2004 at 05:52:51pm
Yes, you can use it, it hangs a little lower than the aftermarket type. On 21st Jan, 2011 fastcarl said:
23rd May, 2004 at 08:03:25pm
its also a smaller pipe... so not good for ultimate power!
AlexF |
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
23rd May, 2004 at 08:44:00pm
What diameter should the down pipe be as a minimum? and what diameter should each individual diameter be per port?
23rd May, 2004 at 09:47:49pm
thats a hard one to answer...
AlexF |
23rd May, 2004 at 11:36:50pm
Alex, not being funny?, but have you actually compared the two?..the metro item does hang lower.Yes a slightly thinner inside diametrer but only as wide as the exhaust elbow(call it what you like).......
24th May, 2004 at 08:21:40am
well I've comapired the two types I have...
AlexF |
24th May, 2004 at 08:30:14am
My maniflow one was definately larger than my std metty turbo one.
24th May, 2004 at 11:04:04am
Try it if you want Iain, But you might want to measure the OD where the clamp sits first... I don't reckon there is much scope at all - not if you want it to be robuust at least! On 17th Nov, 2014 Tom Fenton said:
24th May, 2004 at 11:54:42am
Yeah ill see what material there is there, also be good to machine a decent face rather than rough casting to sit the dowpipe on!
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
24th May, 2004 at 02:47:12pm
I have a maniflow system fitted;
TurboLessTosser |
24th May, 2004 at 06:11:57pm
Im confused here, I have this exhaust from huddersfield mini spares (playmini)
24th May, 2004 at 08:02:51pm
I was told that it is best to use a back box that has been specifically packed for a turbo application such as the maniflow exhaust
Edited by b12 on 24th May, 2004. TurboLessTosser |
24th May, 2004 at 08:24:12pm
b12 im after a turbo downpipe, drop me a mail turbo 16v k-series 11.9@118.9 :)
24th May, 2004 at 10:24:58pm
Sounds like more work!
24th May, 2004 at 10:41:10pm
Turbo's arent bothered about any back pressure, any 2" system will do the job. How many boxes depends on what sound you want. Im not going with any and i still think it will be fairly quiet. |
24th May, 2004 at 10:48:01pm
thing is, i cant find a break point in the link pipe behind the knuckle joint like in the pics in the FAQ last time i looked which confused me, ill have to have a good luck and bring the metro roudn to the garage again tomorow. The engine is coming for it on sunday so ill be selling that! More mini turbo money!
24th May, 2004 at 10:57:01pm
there is a break about 12" after the knuckle, just the same as a normal mini exhaust.
24th May, 2004 at 11:09:43pm
OK thats great! because i spent about two hours cutting my link pipe shorter and shorter to get it just the perfect length pertruding from the rear of the car Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
24th May, 2004 at 11:13:00pm
Sorry, When i get this new metro engine for the metro turbo (its coming on sunday, guys rebuiding it up wiht new gearbox etc atm) Will i just need a metro manifold? Ive never seen one. Wil i be able to use the same exhaust system from this "break" to the rear? Sorry ive never seen the manifolds though. Other than that, can i use a stage one kit style exhaust system from a mini? eg, seperate inlet, twin lcb pipes and a Y piece? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
