Home > Technical Chat > Whats the difference between a K100 16v head and a K1100 16v head?
doctormini
Member #: 849
Yeovil,ZomerZet! The Land of the Cider tree!
Whats the difference between a K100 16v head and a K1100 16v head? Ive been offered a K100 16v head with cams throttle bodies etc? Someone said the Cams might be different?? Any help would be greatly appreciated! Thanks Rob
I stand corrected.
Edited by Rob H on 5th Apr, 2007.
johnK
Member #: 690
Norfolk
there was a k1 16v which predated the k1100's
jk
If Carling made Mini engines
doctormini
Member #: 849
Maybe thats what this chap has got then? Does this fit the mini? or is it totally different to the K1100 and K100s?
There is deffo a K100RS 16v, or the correct term is 4 valve *wink*
doctormini
Member #: 849
Thanks Mini Sprocket
so are the k100 16v and k1100 16v cam's interchangable?
johnK
Member #: 690
Norfolk
yes
John,
just got the SC 16v build guide, jolly good stuff*happy*.
johnK
Member #: 690
Norfolk
Thanks Joe - hope its inspiring!
JK
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
so are the k100 and k1100 the same head?
16V project underway
johnK
Member #: 690
Norfolk
the k100 rs is basically the same head as the K1100's - the "normal" k100 is an 8v job
On 4th Apr, 2007 mini13 said:
John,
What are you up to Joe?
You've got a 7 porter to be getting on with.
