Home > Help Needed / General Tech Chat > bar/psi conversion
adam1330
Member #: 238
essex
i have a bar boost guage and was wondering if any one knows about a conversion rate to work out the psi..its just that everyone talks of boost pressure in psi..
PaulM
Member #: 206
About 14.6 psi = 1 bar
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
adam1330
Member #: 238
essex
mine is running at about 0.6 bar,which i've just worked out to be about 8.5 psi,correct?
i think i may go and twist my bleed valve a bit more....
to convert Bar to PSI, multiply by 14.6
to convert PSI to BAR, multiply by 0.0685
Easy peasy!
