| Home > Help Needed / General Tech Chat > Exhaust elbow | |||||||
166 Posts Member #: 221 Advanced Member |
24th May, 2004 at 01:55:28pm
By exhaust is blowing out slightly from the elbow at the bottom of the downpipe. Is there anyway to fix this, there is no holes, just seems to be a slight escape around the knuckle......exhaust paste???? |
24th May, 2004 at 02:30:04pm
nah it moves as the engine rocks...
AlexF |
24th May, 2004 at 02:35:51pm
yeah no real way to solve it, exhaust paste just goes hard and they're will just crack when it moves. Wouldnt of thought it should leak that much if its fairly new though. |
24th May, 2004 at 04:01:24pm
the rest of the exhaust is brand new, just not that part.
24th May, 2004 at 04:43:28pm
I've often found some downpipes, even from the same manufacturer, to be different in how they fit...
![]() 323 Posts Member #: 41 Senior Member |
24th May, 2004 at 05:24:09pm
Also a small tip that i have picked up. If you get a new downpipe, or keep the old one, run some coarse wet n dry around the top of the downpipe to makeit smoothe, you can rub away the weld that runs down the inside and any other imperfections, i know that the cast elbow isnt perfect, but doing this to mine made a huge difference, still very slightly blows but its a huge improvement. Hope this is of some help. And the bottom steady that dave has mentioned is also a good idea. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
