Home > Help Needed / General Tech Chat > Copper washers
Nick
Member #: 154
Midlands
Here's goes possibly a stupid question but thought i'd ask anyway.
I need a couple of new copper washers for my turbo oil feed banjo bolt, i don't reckon i'll have much luck trying to source any tomorrow so can i just make my own?
was thinking of flattening out a bit of copper pipe and cutting a piece out with a hole drilled through it. Is this gonna work or just be a waste of time?
Doodles_Mcpooh
Member #: 1252
Cornwall
I needed them urgently and had skill to do it and the brains to think of it in the first place I would do it. Can't see how it would be any different as long you make them the right size.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
After you have bashed it about for a while it'll need anealing, easy enough with a blow torch though.
Nick
Member #: 154
Midlands
well i'm going to pop out in a bit and see if there's any motor factors open...if not i'll see halfords have got any of them expensive plastic tat boxes with any in.
roger, is that annealing with a blow torch just heating it up then dunking it in some water, or do you let it cool naturally?
RogerM
Member #: 1217
Air cool, slower the better.
Nick
Member #: 154
Midlands
cheers dude :)
just off to see what halfords have to offer
Kean
Member #: 341
aka T2clubby
South Staffs
You may have trouble drilling the hole in such thin copper dude, it will snag very easily .
Leonard
Member #: 806
Cirencester, Gloucestershire
i thought you had to quench copper to anneal it? and steel let it cool naturally?
Quenching any hot metallic material generally causes it to harden, if you want it soft let it cool slowly in air.
yup, oven is best, then switch it off and leave it in there to cool with the oven, much better than cooling in cool air.
MarkGTT
Member #: 1194
Shropshire.
cant you just use fibre washers for this? not something i have done, just wondering if its possible, as i need to change mine.
