Home > Help Needed / General Tech Chat > iain :)
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi iain, just to check, the braided oil feed pipe you sent me was very thin in inside diameter as compared to the original, from the connections right through the pipe, is it anything to worry about?
you would be suprised how little oil a turbo needs and uses
Carl
Member #: 95
liverpool-on-sea
it might be a bit thinner but dont worry at about 50-60psi of oil running through it, your turbo will get plenty of oil *tongue*
jamesfawcett
Member #: 218
ok great *happy* ill post a pic of it fitted tomorow, showing where i have guided it etc
It will be fine mate, its exactly what nearly all turbo'd minis run *smiley* its from the same place that all the rest come from *wink*
Just needs consitent pressure not masses of it.
