| Home > Technical Chat > fuel pressure regulator help | |||||||
![]() 124 Posts Member #: 1428 Advanced Member Cleveleys |
10th Apr, 2007 at 08:47:13am
There seems to be 4 inlet/outlet pipes on the regulator.
998 turbo in progress.... DONE..........KNACKERED LOL |
10th Apr, 2007 at 09:03:10am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
10th Apr, 2007 at 02:27:52pm
yeah cheers, where it says "H/P fuel in", is this the feed from the electric fuel pump?
10th Apr, 2007 at 03:04:47pm
On 10th of Apr, 2007 at 02:27pm chappers said:
yeah cheers, where it says "H/P fuel in", is this the feed from the electric fuel pump? H/P = high Pressure, so yes from the pump On 10th of Apr, 2007 at 02:27pm chappers said:
Do i need to have a return to the tank? If so i'll need to mod my fuel tank then?!? Yes you need a return to the tank. However, you can put a T-piece in the low pressure pipe between the tank and pump rather than mod the pump. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Apr, 2007 at 03:09:58pm
ah right oh, cheers Wil.
10th Apr, 2007 at 03:27:05pm
You have to have a high pressure (45psi) electric (usually roller vane type) pump.
10th Apr, 2007 at 03:46:17pm
right thanks 998 turbo in progress.... DONE..........KNACKERED LOL |
