Home > General Chat > vizzard carb mods for a turbo?
mic
Member #: 1271
they worth doing?
IMO, no.
Others have done though...
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I agree with Dave. My NA 1380 runs the mods and it works very well but it's a lot of effort which I don't think would be rewarded in a turbo application.
any boost is added on top of whatever power you have , and anything you can do to increase the power of the engine , whether its head flow carb flow manifold flow etc ,is worth doing ,on the other hand , if you are making an engine that will rev to a point that needs the carb to flow more air is another point , if the carb flows enough for 6000 rpm , in a naturally aspirated engine without making a restriction and your turbo is going to a rev limit of 6k ,then there is no point in making the carb flow more .
on the other hand if your maknig an engine to rev to 8 k and the carb starts creating a restriction at 6500 , then its wirth doing whether it na or turboed,it means that you will make more power on the same boost ,so you can run less boost to reach your goal .
regards robert
Kean
Member #: 341
aka T2clubby
South Staffs
In my opinion, its one of the few mods that you can do for free, so why not.
it does help, but im not saying how much
i'm along the "its free and easy to do so why not" kind of route!
*smiley*
JT
Member #: 637
Hertfordshire
right what vizzard book is this in?
i have one on modding your mini with suspension mods the lot but i carnt find these carb mods i hear about all the time!
also theres nothing in my version about turbo minis (if there is a version with that in?)
is it the yellow book? is that just on the engine?
cheers
josh
My build thread..
AL
Member #: 1347
Croydon (South London)
I think its in the bible (tuning bl's a series). from what i remember its all about making the butterfly shaft less of a restriction by filing the bolts down and cutting half the shaft away where the butterfly bolts to it. To be honest i think the gains are not worth the effort on turbo engine.
*smiley*
Id tend to agree too...
if its free, why not. It wont do any harm if done correctly...
But will it make any difference ? Id say no. Even in extreme cases, if it did make a difference, it would probably be so small, you wouldnt notice.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
It's in this one...
On 7th Nov, 2008 Nic said:
naeJ
m
I've already shown from flowbench testing what size 'hole' you'd need in a piece of plate to act as an equivalent flow restrictor - this was 37.5mm.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=513
So, lets work out the area:
(Pi*(37.5^2))/4 = 1104.5mm^2
Dia of the butterfly disc is 44.45mm.
(Pi*(44.45^2))/4 = 1551.8mm^2
Area of the butterfly shaft is:
44.45*5.95 = 265mm^2
*assuming square ends on shaft and a 15/64 shaft diameter - I don't know what it is though)...
Hence area at butterfly = 1552-265 which equals 1287mm^2.
If this was less, or within a few percent of the 1104.5mm^2 of the plenum restrictor - I'd say the mod was worthwhile.
I just can't see how making any area larger than the greatest restiction element will make a significant differnce however???
Anyone get what I'm trying to say?
AL
Member #: 1347
i think i get you TD. Like if its gotta go through a bottleneck further down in the system is there any need to open it out significantly more than this earlier???
RogerM
Member #: 1217
Chain is only as good as it's weakest link..
Totally....but the same logic would make sidedraughts etc an odd carburettor.
Buying that big carb, the choking it to the hilt.... right at the mouth of the carb.
But given its boosted air, does the restrictor actually restrict ?
Or does it simply speed up airflow over the bridge causing it to lift more fuel, then slowing again once past it ?
hard to know really....and one I cant say, as once I had an IC on mine, I never had any restrictor in place.
Chokes are something else though - they are designed to speed up the air; something you can't possibly accuse the restrictor in the plenum of, with it's exceptionally 'wierd' shape that is nothing like a bellmouth, but clearly works well.
Easy test in this case is to put a box-stock SU on a flowbench, and see what can be dragged through it, and then compare to a factory plenum.
If the carb has a larger number - then there is the answer.
Now, who has a flowbench LOL!
Edited by turbodave16v on 11th Apr, 2007.
take daves words as gospel!
how does he get his woks so shiny!!!
whoaaa there silver... I am only applying (what i feel is) common engineering logic to it... I'd happlily hear from anyone who actuallly knows the full answer - or can pop their carb on a flowbench for example. Gospel is not the correct word :)
Do the same airflow principals apply, for air under atmospheric pressure, as to boosted air ?
The restrictor used may be an odd shape....but is that 100% by design, or because it was easy and cheap to make it like that ?
Vizard does touch on restrictors for boosted carbs a little, and they look nothing like what BL used on the metro.
What do turbo Dellortos use ? do they have any form of restrictor at the mouth, or do they simply choke em down ?
http://www.geocities.com/jharkola/1380turbo4.html
Perhaps TurboPhil would be so good as to show us what the inside of the janspeed plenum looks like - and how it compares sizewise to the chokes (I seem to recall Jukka asking phil this some time ago - or it might have been a jetting Q ???)
In all the years i've had it i've never actually taken the plenum of the carb ! Lol.
I'll take it off at the weekend and get some pics. *smiley*
get some pics of your sister whilst your at it phil
T3Tone
Member #: 252
Sunny suffolk
LOL@Nic
-MINI CLUBMAN 1380 TURBO-
