Home > General Chat > Cant work out the fuel pump switch
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi, im still trying to compare the mini wiring diagram to the haynes diagram to work out how to safely wire up my fuel pump. Do i earth it on the oil pressure switch tab on the front of the engine where the yellow/brown wire goes to, and take a +ve feed from the fuse box from a tab which is live when ignition is in key position I or II? Ill keep trying.
there is a diagram in the "how to section" mate.
Think it explains it all.
i bought a saftey fuel pump switch from merlin
i put a whole new wiring loom in just for the fuel pump and this switch cuts supply to the pump if i have an off
jamesfawcett
Member #: 218
k ill try merlin motersport
